Question about Kirby Generation 3 Bagged Upright Vacuum
Motor getting really loud!
It's still sucking, but it's really loud, motor-wise. Is there something that I could do regarding troubleshooting before I take it in? I live in the country and am several hours from a repair shop.
  • 357 Answers
Your Kirby most likely needs a new fan. Please see this link to get the part and do it yourself repair instructions...
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Marci
Posted on Aug 28, 2008
Intensity vacuum really loud
Loud vacuum is usually a broken fan which requires pulling motor.
Jan 26, 2014 | Electrolux Vacuums
When I turn the vacuum on it sounds really loud, louder than usual, and after a few minutes it smells like burning rubber around the canister. The vacuum is still sucking.
The armature is probably missing a plate and the motor is about ready to burn up, but check the filter and screen on the bottom of the motor first. The screen can be checked by removing the filter and looking up at the motor from below. Clean if necessary by removing the motor. Unplug the unit first. If the motor sounds rough and smells like something electrical burning. It's going to need to be replaced. Check your model # and order a replacement. Pretty easy to install if you get the right motor. Get the foam gasket for under the motor if your replacing a three stage motor.
Jun 06, 2010 | Electrolux Centralux Vacuum
The thing is soo loud its really squalling
If you smell any burning smell like rubber it would be the belt slipping or something jambing the brush. If not then it is either something jambed in the motor or the fan of the motor or the brushes and or armature on the motor are going, which if its the last one you would need a replacement motor.
Mar 15, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
POWERMATE HEAD DOESNT SEEM TO HAVE GOOD SUCTION AND IS LOUD
suction wise have you checked the internal pipes on your vacum as for the load noise if it is quite a load noise a humming noise it is ure motor so not worth fixing motors r pricey for a vacum
Feb 03, 2010 | Kenmore Vacuums
Filter being sucked into the motor
There is no way someone can hear what your vacuum is doing over the phone. Be cautious of anyone that tells you that.
If there is a clog anywhere in the lines either in the wall or the hoses it will have really high RPMs because there is no air movement slowing down the impellers. Clogs on these units are sometimes hard to clean out.
If you have a bagged unit, make sure to replace the bag. If you don't have bags then you probably need to clean out the filters and possibly replace them. I would recommend you use bags. You don't want dust and debris going into the unit's motor.
If you hear a loud grinding noise then it may be the fan or bearings in the motor. I technician could easily determine this with just a sound.
the unit should come off the wall fairly easily.
Aug 21, 2009 | Beam Industries 2775 Serenity Plus Central...
I have a Harmony vacuum that's a couple years old. I recently sucked a fair amount of dog hair into it and was unaware something was amiss since the things so quiet. It just shut down and wouldn't come...
Hi There,
Nope, I don't think you torched the motor. I believe this model has a thermal cut-out on the motor that prevents this. I am pretty sure that the vacuum is blocked somewhere, you see, the air that is sucked in is the same air that cools the motor. When the vacuum is blocked, the cooling stops, motor overheats and the thermal trip jumps in. Ten mins later, the trip kicks out (as the motor cools) and away you go, but until the blockage is cleared it will keep doing this. The blockage could be anywhere right up to the turbine on the motor itself so, unplug it, get the screwdriver out and get going. Start with all external hoses\channels before tackling internals using a long piece of dowel or similar poking thingy.
One final note, you may well find that the pet hair managed to block the system by getting stuck on some other object that was already there (usually something silly like a toothpick) pet hair doesn't usually block vacuums on its own. Make sure you clear everything out or the problem will re-occur.
Hope this helps.
Kind Regards......Dave
Jul 17, 2008 | Electrolux Vacuums
VACUUM CLEANER REPAIR
If the motor is real loud, then it is bad and will have to be replaced. Either the fan or motor bearings have gone bad.
Dec 18, 2007 | Vacuums
Kirby Generation 3 Bagged Upright Vacuum Logo
221 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
