Question about Orion1934 19" TV
Original Remote One day while watching tv the original remote did not work anymore. I replaced the batteries, but still nothing. I then opened the remote and looked inside but did not see anything unusual. Can you help me with this problem??
  • Anonymous Sep 02, 2008
    i have the same problem
    Scholar:
  • 173 Answers
Some or most remotes flash a red light as they work.... there is a card you can hold in front of remote to see the infrared working. if not remote .. I have seen alot remote recievers fail inside the set. and it was mostly due to standby voltage failure .....pinpoint? get a shematic and check reg. ic and zener diodes... fuse resistors. 5volt standby
Posted on Sep 14, 2008
Have Toshiba TV Model# 50L1350U Serial# D15248T20387L1 problem will not come on anymore ,I have resetted it several times came on two times i did it , but now the reset does not work
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before replacing the main board, check the infrared emission of the remote control too. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=F8oYoZslgbs LG Remote control - Open - Search [How to open LG Remote control]
https://www.youtube.com/watch?v=do41DlsZHmA [ open, battery change Toshiba]
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jan 17, 2017 | Toshiba Televison & Video
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
One day the remote stopped working. We changed the batteries to no avail. The led lights on both the TV and remote do not light on anymore. The TV turns on/off using the power button and I can also use the...
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
https://youtu.be/wUpnETSm6_k
Jul 13, 2017 | Insignia NS-27RTV 27" TV
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
Hi,i have a sony tv and the original remote is an RM-Y173 and i cant use it it want work anymore it just stopped.So what i did is i changed the batteries on the remote and still nothing .How can i fix it?
ok mam,..did u already program it to your tv?,..if so,..try to re-program it,..& if still not working then,..u may want to replace it,..if so give me a call: 1 800 281-8860
Mar 29, 2010 | Televison & Video
Liftmaster 973LM. Remote opener does not work. Replaced battery - still does not work. Original owner left no manuals. Works with outside pad and inside button.
ONCE YOU REPLACE THE BATTERY YOU NEED TO REPROGAM THE REMOTE.
WATCH THE LED NEXT TO THE PROGRAM BUTTON WHILE YOU PRESS THE BUTTON ON THE REMOTE IF IT FLASHES THE REMOTE IS SENDING A SIGNAL AND SHOULD WORK.
IF IT DOESN'T FLASH THE REMOTE BATTERY MAY BE IN BACKWARDS OR THE REMOTE MAY BE BAD - IT IS NOT SENDING ANY SIGNAL AT ALL.
HOPE THIS HELPS
Jan 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
Everything slowly went wrong
Most likely you have a locked up micro on the main board. You would need to have the main board replaced. If the set is not under warranty your cost to repair would exceed your cost to replace.
Sep 11, 2007 | Insignia IS 20" TV040919 TV
Remote control not working
if you still have a problem (and the tv!) email me at gmail.com
May 01, 2007 | Protron PLTV-32 Television
Orion1934 19" TV Logo
56 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
