Question about KitchenAid Architect® KEMS308SSS Stainless Steel Oven
KitchenAid Wall and Microwave Oven Combo - KEMS308SSS
Anyone has comment on KitchenAid wall and microwave oven combo - KEMS308SSS? I would like to hear some comment on the oven before I place an order.
  • Alexandre Hart Feb 22, 2012
    well i just bought one in november 5 2011, and since then i had a problem with my microwave, and still not fix...it doesn't stop after the tiem runs out,you have to press stop or open the door to have it stop, and the y cant find the problem, and they have a poor client service and makes you feel like you are the problem. If i were you i would choose something else then this...
After using the microwave for a month, the amount of time to heat has increased significantly. For example, 1 cup water now takes 3 minutes to reach 158 deg and 4 min-40 sec to reach boiling (212 deg)
This model KEMS308SSS02 was installed in July 2008 in a new condo. It was never used until Feb. 2011 when we moved in as the first owners.
Any advice would be appreciated.
Posted on Mar 18, 2011
Have had this oven for 8 years. At least three times, usually after using the clean cycle in the main oven, the latch mechanism has broke and the oven door will not open. In March they installed a 'new design' to prevent this. It's seven months later, and it broke again. Has anyone had similar experiences? How did you resolve?
Posted on Sep 16, 2008
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Kitchenaid selectra
possible but unlikely. they are physically connected?
Mar 07, 2014 | Ovens
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Sep 10, 2012 | Electrolux ICON Designer E30SO75ESS Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
KitchenAid Architect® KEMS308SSS Stainless Steel Oven Logo
765 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
