Question about HP Pavilion a1410n (ER890AA) PC Desktop
Lost power my pc shut down 2 days ago when i tryed to turn power on the light stays red not green and no power seems to be getting through
    Genius:
  • 1,226 Answers
Open your system units and then refix the hard drive, memory, video card..and all connection inside.
may this help,
melnavz
Posted on Oct 23, 2008
    Novelist:
  • 183 Answers
Unplug all the cables including power cable...
Then Press the Power button at the Front and hold it for 20 seconds
then connect the Power cable and monitor cable and turn your computer back on.
i am sure your computer is going to turn back on.
and if it doesnot turn on ask me again i can give you more help for the same as i am a Desktop Engg. and worked for HP and working for IBM now.
Thanks
Posted on Oct 26, 2008
Can't turn my a/c off Or fan. I hit theoff button & just changes settings. Other than turn the car off itself, I can't figure it out. Earlier in the year rebooting the car'd work. No more.
Laptop not shutting completely (Power light and fan stays on ...
www.tomsguide.com/.../laptop-shutting-completely-power-light-fan-stay...
3 days ago - I have to hold the power button for 5 seconds for my laptop to turn offcompletely. ... I tried removing my battery completely, and started the windows with my A/C adapter and then shut it down ... when i shutdown my pc , my pc has get shutdown but the power light in my cpu tower ... Can't find your answer ?
Nov 19, 2015 | Computers & Internet
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Sep 22, 2009 | Philips 42PF7421D 32 in. LCD HDTV
PS3 shut down during mid-game/now it will not eject the game disk
not a solution but a possible answer it is possibly the ylod (yellow light of death) it seems a few people are getting this and my ps3 has broke aswell even sony dont know what is wrong with it. but your problem sounds like the ylod
Jun 07, 2009 | Sony Playstation 3 (PS3) Console
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Powers on shuts off after 10 seconds- red/green flash
its probably the bulb. if the red and gren lights are flashing simultaneously, than that means the bulb is burnt amd you need to order a new one and replace it.
hope this helps
Sep 22, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Jun 14, 2007 | Hitachi 50EX20B 50" Rear Projection...
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
HP Pavilion a1410n (ER890AA) PC Desktop Logo
147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
