Question about DCS RGS-305 Professional Gas Kitchen Range
Oven The oven doesn't light and it feels with gas. I see what I believe is a "pilot light" but it doesn't light up and heat up. Only gas comes out!
The igniter is not getting hot enough. It can get hot enough to allow gas to flow but not quite enough to ignite the gas. It is an easy fix. The igniter is usually under the floor of the oven.
Posted on Nov 01, 2008
I have a gas stove/oven, when I turn on the oven the pilot light comes on but the burners don't ignite to heat up the oven. was told that is was not the element if I have a pilot light ????
Heater elements are found in electric ovens, you have a gas oven. It sounds like your main gas valve is not opening because the pilot would light it if it was open. It could be the gas valve itself of the flame sensor. Best to get a tech on it.
Jan 28, 2014 | Frigidaire FGF337BC Gas Kitchen Range
Gas oven wont light
Check the pilot light to ensure that the thermostat is in the flame. If a flame from the pilot is not heating the thermo, then the gas will not flow, so that your house doesn't fill with toxic fumes and kill you.
May 23, 2012 | Kenmore Kitchen Ranges
I have a Garland Sunfire 36 inch gas Range. oven does not come on again after reaching temp.
You probably have a bad thermocouple. Try cleaning it off with sand paper. It's the part that the pilot light is igniting.
Mar 15, 2012 | Garland SunFire SX-10-26 (Gas) Stainless...
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the in that case that gas valve would need to be replaced
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
Unable to locate where o re-light the bake burner on this spectra xl44 oven
Your oven does not use a pilot light it has a electric igniter that comes on when the oven is turned on and that is the most common thing thats wrong with a gas oven when it doesn't heat ..that the electric igniter is defective
Sep 16, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
May 18, 2011 | Ovens
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven does not work.
    Just a guess. There may be something called a thermo-coupler which needs to feel the heat of the pilot light before it will allow the gas to turn on. If it's not working ... no gas.
    Jul 08, 2009 | Ovens
    Maytag gas oven doesn't heat, but oven's pilot light is on.
    Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
    Mar 03, 2017 | Ovens
    Oven pilot light will not stay lit
    The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto and find your model then the part number.
    Sep 04, 2008 | Vulcan 60L Gas Kitchen Range
    DCS RGS-305 Professional Gas Kitchen Range Logo
    228 people viewed this question
    Top DCS Kitchen Ranges Experts
    John Tripp
    John Tripp
    Paul Carew
    Sal De
    Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
