Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
No power I have a samsung hcn4226w. The convergence was bad. I had a blue ghost type of effect cme on here and from sources found out it was the convergence board. well in the meant time i was watching it and then it just turned off has not turned back on since. about 3 weeks now.i still order a convergence board got it today installed it and still no power. i read a post hat you helped with and you sad to unplug the red,green,and blue and try turning on. still nothing you also adding if that didn't work you need a new deflection board.where can i find a deflection board at?? any help would be greatly appreciated.thanks gain
  • Samsung Master
  • 8,617 Answers
You can get a replacement deflection board at the following link. If you dont know which one your model requires leave them a email with your model number and what youre needing they respond quickly and will provide the proper one for your model.
http://servicemanuals.vstore.ca/
Posted on Aug 28, 2008
Convergence problem on my Samsung 42'' model hcn4226w
Yes, your diagnosis is correct, convergence board is bad and needs to be replaced in TV.
Aug 19, 2009 | Samsung Televison & Video
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Jul 16, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226WX has green and red ghosts very bad
Probably bad IC's (color or convergence amplifiers). Soldering and knowhow required.
Apr 26, 2009 | Samsung HCN4226W 42" Rear Projection...
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
You have a convergence problem.You can replace this module cheaper than it can be repaired.It is so easy to do and electronics skill level is not required.If you can unplug the TV and remove the rear cover,then you can do this repair yourself.1 screw and 5 connections(plug in) is all it takes.The part number you need to order is BP95-00142E convergence amp. I would google search it and find it at the lowest cost to you.Good luck and please rate my information.
Jan 30, 2009 | Samsung HCN4226W 42" Rear Projection...
Bowing screen
You have bad convergence ic's. You can take the convergence board out yourself and take the part to a repair man to have him replace the ic's. I've had it done twice on my tv, it cost about 200 bucks.
Nov 04, 2008 | Samsung HCN4226W 42" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226w green color problem
The green that you see is the DMD board (digital mirror display) going bad. Very common for this model.
Mar 24, 2008 | Televison & Video
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung hcm4216 rear projection
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Henry  Thomas
Henry Thomas
