Question about HP iPAQ H4155 Pocket PC
Regaining ipaq4155 partnership after reset
My iPAQ lost battery power to the point where it hard-reset. Now that I recharged it, my ActiveSync no longer recognizes it and wants to create a new partnership. Is there any way I can re-establish the partnership? If I create a new one with the same name, it returns an error message. Thanks for the help!
  • 490 Answers
SOURCE: Removing/restoring partnership
acc to me, partnership once deleted due to hard reset on ur smartphone will not be created under the same name until u delete the same partnership from active sync on pc. To delete the partnership open active sync>file>delete partnership..then create new with the same name with ur smartphone.
hope this will help
Posted on Oct 19, 2007
0 characters
1 Points
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
My Dell x51v Axim suddenly no longer communicates thru ActiveSync. Even though it is firmly connected with a USB cable, ActiveSync will no longer recognize it. I have uninstalled and reinstalled...
First try a "soft reset" - this clears all open programs and "reboots" the Pocket PC. When the Pocket PC powers back up, you'll start with all active programs closed and the device should be ready to use. This procedure is intended to reset the Pocket PC if it is malfunctioning or has become bogged down.
This reset is also sometimes necessary after software is installed.
The X51v can be soft reset by pressing the recessed button on the rear of the unit above the battery.
Try to reconnect with your PC. If that fails - on the Axim - go to start - settings - connections - usb to pc and untick enable advanced network functionality - then see if you get a connect.
If you are still not getting a connection you will have to try a "hard" reset. However be aware that a "hard" reset wipes the RAM and returns the Pocket PC to its factory specs.
In effect, the Pocket PC will be just as it was when you purchased it.
All data entered, preferences set or software installed (other than ROM updates) on the Pocket PC after purchase will be lost after a hard reset and will have to be transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
The hard reset is performed through the following procedure;
With the unit turned on, press and hold the power button at the top of the unit. While holding the down power button, use the stylus tip to press the "Reset" button mentioned above. Allow the screen to fade to off. Release both buttons. The unit will power back on and display a menu to confirm the hard reset request.
Make sure you have downloaded and are using the newest version of microsoft activesync.
Try the reconnect and let me know how you get on.
Hope this helps. Please do rate my answer. Thanks.
Sep 04, 2009 | Dell Axim X51 Pocket PC
PIM ino lost from ipaq 1950
did a hard reset. booted up ok. did activesync with my other PDA onto computer and then sync'ed with 1950.
Dec 01, 2008 | HP iPAQ rx1950 Pocket PC
How to soft reset
There is small button that is usually in the battery compartment that you can press with a paper clip to soft reset the phone.
However, a soft reset will not fix your ActiveSync problem.
Here's what to do:
Open ActiveSync and go into the settings/options.
Delete any partnerships you see.
Now verify the following settings with your Exchange Administrator to make sure you have them right:
Server name: (a.k.a. your public server name)
Use SSL: Yes or No
User name:
Password:
Domain: (a.k.a. your private Windows Domain)
Now verify that your Exchange Admin has enabled ActiveSync for your account.
If the settings are correct and ActiveSync is enabled, you should now be able to set up working ActiveSync partnership.
Jul 04, 2008 | HTC S710 Smartphone
Activesync problems with IPAQ 1940
 connect the cable with pc , open the active sync on ipaq then connect the cable with ipaq..if not still soft reset ur Pocket PC and reconnect.
Sep 17, 2007 | O2 Xda IIs Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
hope this will help
Sep 19, 2005 | HP iPAQ HX4700 Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Please help! Cannot sync....
You need to install Activesync onto your PC. Activesync comes on the CD that came with your Ipaq , or the latest version can be downloaded from here... http://www.microsoft.com/downloads/details.aspx?FamilyID=2eb5bd80-d52c-45 60-ae11-da92f2b229fa&DisplayLang=en Then from your PC (not your IPAQ), open Activesync, click on File, Get Connected and do NOT cradle the IPAQ until it tells you to. The Activesync on the IPAQ is for wireless syncs, which cannot be done until youu establish a partnership with this first wired sync. You will need a wireless network to do a wireless sync.
Sep 07, 2005 | HP iPAQ RX3700 Pocket PC
HP iPAQ H4155 Pocket PC Logo
18 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
