Question about New Home HF-106
Threading my sewing machine
I need to know how to properly thread my New Home HF 106 sewing machine. Thank you for your assistance:)
  • 1 more comment
  • Anonymous Mar 21, 2014
    Lost my New Home HF-2022 manual and need to replace it so I can work my sewing machine.
  • Anonymous Mar 25, 2014
    How can I get a replacement for my lost manual for my New Home HF-2022? I need the manual tonight.
  • Anonymous Mar 28, 2014
    looper disconect
  • 323 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
How to thread this machine
New Home Model 532 Sewing Machine Threading Diagram
or search the internet for:
New Home + (Model #) + threading diagram
Hint: Always Raise the Presser Foot when threading the upper thread. This insures the thread will seat properly in the tension disk.
Jul 20, 2016 | Sewing Machines
My thread keeps jamming in the shuttle race
try a new needle
try a different bobbin and make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the top thread take up lever
Jan 02, 2014 | New Home HF-106
My needle won't grab the bobbin thread but if I put some fabric in and start to sew the bobbin thread comes through. However, the bottom thread is all bunched up and causes the machine to jam.
the looping on the underside sounds like a needle thread tension problem. 1st off check top (needle) threading then turn machine by hand to pick up bobbin thread
Please put on correct size needle. And check the tension & timings.
Spare foot plastic.what is it used for.supplied with machine
here is a link for feet that go to a janome (new home) sewing machine ,see if the foot you have matches any of these
http://www.sewingpartsonline.com/janome-106-sewing-machine-parts.aspx
if you need a manual you'll have to contact Janome
Sep 24, 2013 | New Home HF-106
Why is the bobbin side of stitching is all loopy
loops on the bottom means top thread isn't getting tension. Re-thread top thread with presser foot UP. Then test your seam again. If you still have loops, tighten the UPPER tension.
Nov 11, 2012 | New Home HF-106
Hoe to thread a New home
sewusa.com has some threading diagrams
or
check with janome website about a manual
sewusa.com also has manuals
sew4less.com
May 17, 2012 | New Home HF-2022
My thread keeps snapping. How can I fix this?
Try releasing the thread tension a little. Make sure that you are using the correct thread.
Feb 24, 2011 | New Home HF-106
New Home HF-106 Logo
623 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
