Question about Palm LifeDrive Handheld
Palm LifeDrive Upgrade Results
I downloaded and upgrade my Palm LifeDrive with LifeDrive Update 2.0. Now there are 2 problems that bugs me; 1) the sync process is very slow; 2) it's sucking juice from the battery faster than before. If possible, I'd rather go back to the way it was. It there are way to reset it to factory installation? If it can't be done, would upgrading to the new Desktop/HotSync Manager help? What about the problem with battery life?
Thanks
  • 1,606 Answers
No need to reset.
Usually the update does the opposite of all of that. What has probably happened is now all of your settings have been set to defaults. So you should check the power off times and make sure what you don't use is turned off. For example if you have bluetooth running it is continually trying to connect to each and every bluetooth device it finds. If you are near other people ie a mall in a office then it will be on continuously. Next to the power used by the harddrive any of the radios wifi/bluetooth draw the most power. Turn it off until you need to use it. Same for the infrared port.
As for the speeds that due to the same thing it was reset back to the default slow speed. Go to prefs
under available connections find Cradle/Cable that's the usb cable. Tap edit. On the next screen tap details. Set the speed up as high as it will go with the flow control to automatic. That will speed up your connection by quite a bit. If you plug into a USB 2.0 port you will transfer much faster than that setting.
You may find other settings are changed as you use the LD. It will work better than before but you have to tweak it. Oh and downloading the desktop won't help.
Posted on Jul 09, 2009
Panels in my Ubuntu9.04 desktop are not responding. When I click on them nothing happens. This happened when I added many Panels and tried to delete them. I think that I had clicked on autohide button....
Dear rajendran102, there are many bugs and problems with Ubuntu's 9.04 version. It is advised to upgrade to 9.10 to fix most bugs. To upgrade, simply follow these instructions: - Click on System, then on Administration. Now click on "Update Manager". - Click on "Check" and enter your sudo password. Download and install the updates, then on the top, click on "Upgrade to 9.10". - After downloading and installing, it shall reboot the system, and you will have Ubuntu's 9.10 version installed.
Do not worry, your files won't be deleted. After the upgrade, everything shall work normally. And if you want, you can follow the same steps, after upgrading to 9.10, so you can upgrade to 10.04 LTS.
Aug 28, 2010 | Computers & Internet
Tip
How can I connect the USB Bluetooth bugs in Ubuntu 8.10?
<p>USB and Bluetooth connectivity errors in Ubuntu 8.10 are the result of two different errors. If you are running KDE, you have a patch on their Bluetooth connectivity problems (see Resources) to download correct. USB connection errors are the result of a bug in the current version of the Linux kernel. Run "apt-get package manager to upgrade the kernel is usually the fastest and most trouble-free. After the upgrade, the system restarts. <br /> <p><br /> <p>1. Open a copy of the console when running a graphical user interface (GUI). <br /> <p><br /> <p>2. Type "apt-get update" and press "Enter". <br /> <p><br /> <p>3. Type "apt-get upgrade" and press "Enter". The window that appears available updates. Find anything related to the kernel that "n" followed by pressing "Enter". <br /> <p><br /> <p>4. Type "apt-get install package-name" where "package name" is the updated version of the kernel. Press Enter. Confirm that you have to install the update by typing "Y" and press "Enter". Once the upgrade is complete, restart your computer. <br />
on Jun 26, 2011 | Computers & Internet
My Palm Lifedrive handheld is frozen and if i put in my password,it will not register as i tap the screen.Can i get help?
Hi you should update the software of the Palm Lifedrive Handheld you can got to manufacturer website and download the software.
Aug 04, 2010 | Palm LifeDrive Handheld
About 1/2 of he time now, my Zire 31 has problems
Either the digitizer is failing or you have a protective screen on it.
I'm not sur eif Palm is still supporting these of if they have changed policies. It used to be a set fee say $85 to fix or echange. If they still do this. then I would find out if they apply the $25 against the repair fee. You can also send it in to several pda repair places who wil fix it for a reasonable fee.
A Tx or Lifedrive is a better palm but can be worth much more. You can find those used all over and may be the way to go to upgrade if you want to save a few $
Mar 31, 2010 | Palm Zire 31 Handheld
PALM DESKTOP CRASHES in new installation.
Make sure you have the latest desktop version which was 414E When you try to reinstall the desktop software DO NOT select or allow update setting over internet. Some of the earlier versions had a problem with earlier xp versions. It is stable and works well with sp2 and sp3 versions of XP so update your windows as well.
May 05, 2009 | Palm LifeDrive Mobile Manager Handheld
Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Dec 15, 2008 | Acer Aspire 3000 Notebook
Lifedrive wifi
Does the wifi work at all after it resets? Have you applied the level 2 palm srvice pack to the LD? I believe the update changes how the wifi operates. If you go to www.palmone.com and go to the lifedrive page you should see a list of downloads for it. If you click on the 2.0 update there is a description of how to tell if you need this or if it is already installed. You just need to check the version of one file. Download and install the patch and see if that fixes everythng.
If that doesn't fix it you may have a more serious problem that could require replaceing or fixing the LD
Oct 27, 2008 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive
just press the time in the top left hand corner of the lifedrive and a dropdown menu comes down with the option "delete" but this is only for apps. if you want to delete media files, search for a file manager on freewarepalm.com
Apr 21, 2007 | Palm LifeDrive Handheld
BackupBuddy VFS Pro supports the LifeDrive?
The readme info needs to be updated. The current readme is actually from the previous version and out of date. It should now look something like this.. (note newest info at top, previous version info underneath) BBVFS 3.1.4 New features include: + added option to backup after HotSync + LifeDrive compatibility fixes Bug fixes include: - some password letters were being ignored - fixed problem of backing up files encrypted with the built-in Security app - blank screen/crash on startup - crashes during orphans processing - no scrollbar appeared when there were more than 10 checkpoints in the list - didn't fail gracefully when trying to restore corrupted backup files BBVFS 3.1, 6.05 * Users may now select which card to backup to on devices with more than one card slot * Backup and Restore of T5 internal drive (!) is now supported * Backup of databases with records > 64K is supported, which will allow backup/restore of Photo/Videos on T3/T5/T650 and "VoiceDial" application * Advanced screen now adds new files to the backup set automatically * Wireless updating (via "About" screen) * Implemented a Palm Source Installer package * Many important bug fixes, including: Several issues relating to compression and encryption "Last Backup" being incorrectly set to "NEVER" No longer will soft-reset if no card is mounted on the T5 TUNGSTEN T5 SUPPORT This build includes further refinements to backup and restore on the T5 but we have confirmed with PalmOne that there are some issues with the T5 NVFS implementation that require a patch from to completely resolve. We recommend that all users download and install the T5 patch that is available here: http://www.palmone.com/us/support/d...ent5update.html Alternatively T5 users may want to try a program called "DBCache Tool" which you may download here: http://www.jade.dti.ne.jp/~imazeki/palm/DBcT/ LIFEDRIVE SUPPORT We are aware that this release contains some remaining issues with the new PalmOne LifeDrive and we are working to resolve them. Please contact support@bluenomad.com if you'd like to help with testing. BBVFS 3.07, 1.05 BackupBuddyVFS 3.07 is being released with preliminary support for the T5/Treo 650, although there are still some outstanding issues that we are continuing to investigate; specifically: * Power Users with a (near) full device especially may experience "out of memory" errors and/or random resets; restarting the backup or restore operation will usually allow it to reach completion. This is due to issues with the new "NVFS" file system on these new devices that developers cannot currently work around. We hope that palmOne will issue a patch to fix this, and we will continue to try and find a work-around. * Photos and Videos will not be backed up on the Treo 650/Tungsten T5.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Sep 15, 2005 | Palm LifeDrive Handheld
Palm LifeDrive Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
