Question about GE GLD4460NSS Stainless Steel Dishwasher
9 month old GE GLD4460nss
Water did not drain out when we got up this morning and dishwasher will not come on. Breaker is ok and wall switch ok. Wife emptied washer and after reading up on it I pulled front panel on bottom after offing the breaker.The motor spins free and I had wife put in two pots of hot water in bottom of machine to see if a vapor lock. No drain . I saw the two panel lites come on one time after putting on breaker but that is it.The washer was never attached to the new granite countertop when we bought the older updated house and the washer scoots in and out very easily.It has to be pulled out or pushed in just right for the unit to come on ( this has been from day 1 ( 8 ) months ago. We have an autistic son who is going nuts because he can not unload the washer ( his prized job)-----HELP!!!!!!!!-2 weeks till sears can come out.
  • vyankagroup Jan 17, 2009
    I have the same issue, and the electrical connection is solid. It does not drain, and never did. It is a brand new dishwasher that is never used.
  • 1,543 Answers
Order a Non-Wood Countertop Kit GPF65Check electrical connection to dishwasher. All that moving around may have contributed to a poor connection. Test wire nut connections where the household wire connects to the dishwasher by holding wire nuts and tugging each wire to make sure they are firmly attached. Inspect incomming wire to make sure it has not been damaged.
Posted on Aug 28, 2008
GE Profile GSD4010202AA Built in Dishwasher acts as if no power
1. turn breaker off to diswasher. 2. remove bottom access cover. 3. remove cover over electrical connection box on right side. 4. hold each wire nut connector and firmly tug on one wire at at time to make sure none of the wires pull out of the wire connecor nuts. A loose connection here is more common than you might think.
If those are all OK, turn breaker back on and make sure you have power there. (120 volts black to white) If that was OK, then check door latch switch inside door at the top center and wires passing through door at the bottom of the door.
Jul 26, 2010 | GE Dishwashers
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
No power to dishwasher
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
No lights displayed at all and the unit does not turn on. Tryed reseting the circuit breaker
It doesn't work at all If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Mar 31, 2009 | GE GLD4460NSS Stainless Steel Dishwasher
Installation
The incoming hot water can be hooked up independently. The thing you should consider is the drain line. The drain hose and the pump are (obviously) below the tub of the dishwasher (DW). If you route the drain hose through the floor directly, the water in the tub will siphon out. You'll need to route the drain hose to keep this from happening. The way to do that is to route it in such a way that it forms an almost upside down "J", then down through the island. The upper portion of the "J" should be about the same height as the top of the DW.
Also consider the electrical hook up. The proper way to wire it is through a SPST switch (like a light switch) so you can turn power off in an emergency or a servicer can kill power without having to locate the breaker. Some contractors "hard wire" the DW's in (with or without a SPST switch)... others mount a wall outlet so you can plug and unplug the DW if necessary. Either way is OK, only mentioned it so you'll know how your contractor will be doing it.
Just some things to consider. Good luck with the renovation and I hope you enjoy your new Kitchen.
Oct 13, 2007 | GE 24 in. GSD4000J Built-in Dishwasher
GE GLD4460NSS Stainless Steel Dishwasher Logo
128 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
