Question about HP iPAQ H6340 Pocket PC
GSM reception problem
Originally I was thinking that if h6340 goes to sleep mode it doesn't wake up when it gets a call. This might be still valid but since I have used Battery Pro Pack this problem got resolved. I think this is because Battery Pro is polling the device every second so that device can wake up when it gets a call. However, my most important problem now is if h6340 loses the reception somehow (travelling by tube, etc.) "sometimes" it doesn't recapture its reception when you are in a place w/ reception. Even if you go to a place with full of reception the device is looking for a network (in my opinion it stalls in a state where there is no network). Please note that device is not in sleep mode. The only thing to resolve the issue (rather than resetting) to turn off the phone (not pda) and turn on again. To me it looks like a SW problem. Do you have this problem as well?
    Master:
  • 450 Answers
To some degree this is a known problem for the h63XX series. The US version the 6315 has a GPRS update that "helps" the device reacquire the signal. Therefore, I recommend that you contact your cellular and ask them if a similar firmware update is available for your particular unit. Clearly, since the h63XX series has several known issues at this time, I highly recommend you don't use any third-party applications that are not WM 2003 AND 63XX certified and tested.
Posted on Sep 07, 2005
SOURCE:
Hp slate pro 21 goes to sleep mode and can't be turned on
NO OS stated at all, w7/8 or 10 , did it ever get OS upgraded, from 7 or higher? if yes say so. ok?
Do the HP.com long reset yet?>
answered here 10,000 times and 1 million times at HP.com
This is an ALL-IN-ONE PC. 5 years old, (can be)
not a desktop real (atx) not laptop or note book.
Most of these odd duck PC have special keys for Unsleep.?
but this fake desktop has no huge battery.
so you unplug the power pack from the wall
and hold the power button on for 30seconds and release it.
then try normal.
the manual on this PC cover sleep did you read it.
did you ever upgrade the OS? if yes, BINGO. a problem.
learn that sleep mode only works correctly if all drivers are correct for you unstated OS (matched perfectly from HP)
and worse in hibernate mode, more complex. that is.
using slate mode? or hdmi
read page 4 (and page 45 on 30min sleep rule new)
http://h10032.www1.hp.com/ctg/Manual/c04162993
quote. how to unsleep or WAKE this PC is stated in the above manual. I pasted the words here.
Examples include the user pressing the power/sleep button, receiving an input signal from an input device, receiving an input
signal from a network connection with t
he Wake On LAN (WOL) feature enabled, etc.
typing wakes it, mouse wakes it.
if you have power setting set up wrong, the mouse and keyboards go dead and will not wake the PC from sleep.
so hold the power button on for longer, time.
the power button I think is the only button that never sleeps.
note how that button has very unique name, on this PC.
Oct 06, 2018 | HP Computers & Internet
Kodak i2400 scanner goes into sleep mode after 1 hour
Open the Scan Validation Tool. Select TWAIN / KODAK i2000 Scanner. Click the setup button (top left icon). Highlight Default. Click the settings button at the bottom after highlighting Default. Click Device. Power Saver / Power Off values are now shown. Maximum setting is 240 (4 hours).
Jan 27, 2014 | Kodak i2400 - document scanner
Laserjet 1536dnf mfp not waking out of sleep mode
Disable sleep mode or update firmware. Cause this is a firmware bug.
Nov 13, 2013 | HP Laserjet M2727nf Multifunction Printer
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
My iphone is stuck on emergency contact mode with the picture telling me to plug it into itunes. when i do it says sim card is not support the iphone, i have tried everything but it wont even restore.
Are you using a legitimate ATT sim card or are you jailbroken using Tmobile or some other GSM provider? you can try putting the phone into DFU mode. Have it plugged into the computer. and turn it off. Then hold both the upper sleep/wake button and the bottom Home button for 10 seconds. Then when you get to ten release the top sleep/wake button and continue holding the bottom home button until itunes gives you a message about it recognizing a phone in recovery mode. This should allow you to restore the phone.
Feb 28, 2011 | Apple iPhone 3G Black Smartphone
Computer will not wake up from sleep mode
- your comp is in hibernation mode
- go to control panel>>power management>>put to NEVER the sleep mode,hibernation,HDD,battery
- restart system
Mar 25, 2010 | HP Pavilion dv2000t Notebook
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
Waking from sleep mod
Hello
The hinge is a very fragile part of the Macbook. In the hinge goes all the video and sound cables, as well as the backlight power. You can have a hardware problem here with your connectors.
However the sleep mode can also take its time to wake up:
- The hard dive needs to wake its 5400 rpms - The system has to wake - The video has to wake
I would think that a fast internal hard drive, as a SSD drive for example, will wake up much faster.
Hope this helps
Aug 04, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
HP iPAQ H6340 Pocket PC Logo
126 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
