Question about Sony DCR-TRV285E Digital-8 Digital Camcorder
Problem with Sony Hi8 ntsc playback
I am using Dazzle 150 to convert analog to digital
my device is recognized by the computer and will do a capture.
Unable to access the files though because they are on 25 fps (PAL) format. Although the camera says it is NTSC.
At a loss as to how to get the videos downloaded to my PC.
  • 107 Answers
Do you have firewire ( IEEE 1394 } input on your computer if you do. You can transfer direct from your CAM to computer or burn into DVD without using Dazzle 150 see how to do it in user manual if you have not user maual, download from Sony Web
Let me know if you need further assistant
Posted on Dec 10, 2008
I have an old Sony Camcorder Hi8 CCD-TRV98E is it possible to get and kind of wire that will connect it to my pc
You will need a video capturing device as Hi-8 needs to be specially converted onto the computer.
Dazzle is highly recommended for converting old videos to PC,
Here is a link for the hardware and software required -
May 04, 2011 | Cameras
No sound on tape playback.
Are you using the sony software to download and convert the video?
Sep 08, 2008 | Sony Handycam CCD-TRV37 Camcorder
How to convert hi8 tape to cd or dvd
your camcorder has only A / V out.. it does not have USB or Firewire as some later models have ... so you need a Video Capture Device ... those are available as a card that is installed inside your computer or as an external USB device .. some of these devices use only SVIDEO which this camera does not have .. so you need a capture card that will do composit NTSC video ... most of the older ones do that .. then you might need adapters if its connectors dont match your camera .. the capture card or device usually comes with simple video editing software that can burn to a CD or DVD .. or you could use more elaborate software like Nero (nero 9 is the latest i think) .. there are many other editing programs available ..
here is a review of "video capture devices".....
some video cards already have "video in" connector .. its often SVIDEO .. so that wont help .. but some have analog (composit) inputs that you can use ..
here is such a USB video capture device that will work with your camera .. ........
Jan 20, 2010 | Sony Handycam CCD-TRV57 Camcorder
Vista should be able to download this without any issues as it already includes the drivers. i was able to do this with my sony dcr-trv250 painlessly over the ieee-1394 (firewire) port using the DVD capturing bloat-ware (Ulead DVD creater) Toshiba had already installed for me. My toshiba satellite is running Vista Home Premium.
as regards analog hi8 playback, the product manual for the 250 says that this is NOT supported, i.e., it CANNOT play back analog hi8 tapes. Also, i wonder if PAL would be supported here in the US (assuming you're in the US, of course). I would expect only NTSC support. but it's a moot issue, since it doesn't play analog
Oct 03, 2008 | Sony Handycam DCR-TRV140E Digital...
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
How can I transfer video onto a PC
Your camera is Analog model, can't connected directly with PC. You need to install some sort of "Analog-to-Digital video convertor card" in PC to digitize its audio-video output.
Jun 19, 2008 | Sony Handycam CCD-TRV107E Camcorder
Hi8 to Computer for editing
Color: Black Part No.USBG-VX3 VISTA COMPATIBLE USB Video Adapter USB 2.0 Audio/Video Grabber S-video& Composite
AUDIO AND VIDEO GRABBER FOR WINDOWS VISTA GrabBee X+ USB 2.0 Audio/Video Grabber New Generation USB2.0 Audio/Video grabber is the best ideal companion for your portable audio/video application. Real-time MPEG 1/2/4 recording make you have powerful video application on hand. GrabBeeX+ USB 2.0 A/V Grabber is the bridge between your computer and analog camera, VCR, camcorder or other video source. GrabBeeX+ USB 2.0 Video Grabber is small enough to fit in the palm of your hand and is ideal for both notebook and desktop computers. Applications : Video recording & editing Take photo Video email Security monitoring system Features : Small Wonder--Dimensions are (L)81mm x (W)30mm x (H)15mm Audio and video go though USB 2.0 bus (WinXP) to make best performance High speed USB 2.0 data transfer rate for best video recording Encoding MPEG 1 or MPEG 2 format directly use InstantMPEG Technology, Ideal formats for creating VCD or DVD movies Up to 25 fps motion capture capability at 720x576(PAL) & 30 fps at 720x480(NTSC) SnapShot function support Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Recording period setup Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Support Brightness, Contrast, Hue, Saturation, Sharpness control Powerful video editing function include Motion Video Special Effects/ Title Effects/ Picture-in- Picture Effects/ Slow & ast Motion Video Effects/ background music/?color background/ Transitional Effects Plug & Play Low power consumption. Ideal for portable computer too No Battery---No need to install batteries or run off the wall adapter
  • Specifications : Video input : One RCA composite, One S-Video.
  • Video system : NTSC, PAL and SECAM multi system support Audio input : in WinXP, go through USB; in Win2000, go through sound card
  • Motion capture : AVI format from 160x120 to 720x576 resolution MPG format from 320x240 to 720x576 resolution Still image capture : BMP/JPG/TIF/PCX/TGA file format
  • Performance : Up to 25 fps at 720x576 for PAL, 30fps at 720x480 for NTSC Power Source : 5VDC,300mA(max) through USB port Minimum System
  • Requirements : USB 2.0 equipped computer Pentium 4 1G or above 128MB of RAM Windows 2000/XP Sound card
  • Package Contents :
  • GrabBeeX+ USB 2.0 Audio/Video Grabber
  • GrabBeeX+ drivers CD
  • Ulead VideoStudio editing software
  • User's manual
    I have heard this works, going to try one today, I have tried EVERYTHING else, downloading drivers, diffferent programs, firewire cords, so I think this will work, when I googled our specific camcorder, this matches, also, some people are selling the exact sony camcorder on ebay with this included, stating they have used it to connect to their pc. Hope this helps.
  • May 06, 2008 | Sony Handycam CCD-TRV608 Camcorder
    Video transfer from sony handycam ccd-trv 308 hi8 to a computer
    I have a sony handycam ccd-trv 308 hi8 analog camcorder and I was trying to transfer videos from it to my computer. However, when I plug the S-video cable to the handycam and my computer, nothing happens. Does my computer require a driver to recognize the handycam because I cannot find any in the sites of sony for my handycam's model. Or am I using the wrong wire?
    Apr 06, 2008 | Sony Handycam CCD-TRV308 Camcorder
    Camcorder won't playback most Hi8 tapes
    may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
    Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
    Can't use my Sony TRV22 miniDV camcorder to pass through and record Hi8 analog signal to my PC
    Just below, they noted you don't put a tape in the TRV... Otherwise it outsmarts you.
    Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
    Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
    108 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
