Question about Lite On Spark Plug Lite Green LED
No spark i have a new coil and still no spark at plugs
  • artsangel Aug 27, 2008
    please help
  • artsangel Aug 28, 2008
    1987 ford ranger2.9
  • 2,039 Answers
What kind of car and engine size please
Posted on Aug 27, 2008
  • pierre laplante Sep 01, 2008
    its probably ignition module no spark no injectione if when you put our key on if your check enginelight is on if not check fuses
My dewalt 3800 presher washer gas, is not getting any spark. 1) new spark plug 2) new spark plug wire I still do not get any spark. What could it be?
spark plug wire? do you mean coil? if you have no spark. i would check the plug first. then the coil assuming the on of switch is good. unplug the coil kill wire and try it. if it starts then you have a switch or wiring problem. if it don't start it is likely the coil is bad.
Nov 21, 2016 | Dewalt Garden
It mayI have no fire going to the coil or from the coil to the plugs
Have you checked the wiring, the spark @ plug, Power to the coil???
Engine Won't Start No Spark - Auto Diagnosis Repair Help
If your engine cranks normally but will not start because it has no spark, or it ... If an engine has a coil-on-plug ignition system with no plug wires, remove one of ...
No-start, No-Spark diagnosing simulated - YouTube
? 5:13
May 19, 2010 - Uploaded by FrankHurtAuto
Simulation of no start with no spark diagnosing, ... Ignition coiland module test with test light (ScannerDanner Premium lecture) - Duration: ...
getting fire from coil but not to plugs - CarGurus > Questions > Dodge > Ram 1500
CarGurusJun 12, 2013 - 2000 dodge ram 1500 4x4 not getting fire changed distributor cap, coil, pickup ignition, rotor, plugs, plug wires 2 answers. ... 1994 dodge 5.9 just shut off and wont start back up there is no spark or fire from coil or plugs. ... 94 dodge van 318 eng will not start new plugs new crank ...
Ignition Coil Troubleshooting: (No) Fire in the Hole
Jan 27, 2016 | Cars & Trucks
2002 mitsubishi galant 1 and 4 spark plugs no spark ....i need help . . i change the coil and plugs already still no spark..
Look more closely at the 1 and 4 coil, also, check for trigger signal to these coils. I mostly suspect the trigger unit.
Dec 04, 2014 | 2002 Mitsubishi Galant
I have no spark on my 1980 kdx 80 bought a new coil but not sure if that's the issue cause I can feel spark with the old coil but I can't see it any help ??
If you can't see the spark, maybe the gap is set too short?!--Typicaly, with a "no spark" issue, you want to make sure that you have a good spark plug & plug wire/boot. If all those are good, then you need to check your coil...a good coil should test AT LEAST 3.2ohms on a multimeter to provide adequate spark to the plug. If the plug, wire/boot, & coil are all good, then it's a safe bet that you need a new cdi/tci box, as that unit is what sends the signal to the coil to create the spark.
Jun 09, 2014 | Motorcycles
P0302 mis fire, lacks power
Pull the spark plug of cylinder 2. Put the coil on the spark plug. Ground the sparkplug and have someone crank the engine. See if you see a spark. If you have no spark switch coils with another cylinder. If still no spark it could be one of the wires going to the ignition coil. If there is a spark do you smell gas at the spark plug hole? Could be no fuel to the cylinder.
Apr 22, 2014 | 2008 Ford Escape
Ignition coil problematic primary feed
older post.
how many miles, how many miles for the last tuneup.????
The PCM CREATES spark. on all cars since about 1991.
the only changes are where they hid the IGNITOR.
or how may spark coils you have.
my guess, is your enigne is 3.8L just like my 08
where is the coil pack, well see those spark plug wires.
the go directly to the top mounted coil pack. see that?
the PCM monitors the rail coil , the 3.8 has a 3 COIL pack.
and each coil runs 2 cylinders. like this.
so what is the first thing to do here.
easy , put in new spark plugs.
try doing the tuneups. in the glove box guide.
page 433 , at 102,000 miles. spark plugs and cables.
mine has only 60,000 miles, and they both were bad.
spark plugs and HV, wires so I upgraded to NGK mag wires.
and new NGK plugs.
if it still fails, then try a new coil pack.
HV= high voltage wire sets.
Mar 07, 2014 | 2008 Jeep Wrangler
I got code PO 305 on a 2002 Mercury Grand Marquis, what is the spark plug wire part called, is it #5 coil, and should I replace the coil and spark plug and what should the spark plug be gapped at? Thank...
This will have a direct coil over ignition with a coil over each spark plug. The coil is the electrical part over the spark plug. The coil also has a rubber part that is called the boot or spark plug boot. The boots can be purchased separately but the coils will come with new boots.
is it #5 coil,
Have you checked to see if there is any spark coming out of the number 5 coil?
When was the last time the spark plugs where changed? It may be due for all the spark plugs to be changed. The spark plug gap is usually listed on the emissions sticker under the hood. It should be .050 - .056 or very close to that.
May 16, 2011 | 2002 Mercury Grand Marquis
Replace spark plugs on a 2008 4 cylinder tribute
This is a fairly easy job. Do each cylinder one by one (removal and install), make sure to reinstall the coil on the same exact cylinder (DO NOT MIX UP). 1. Remove coil retaining scre 2. Pull upward on the coil to remove. 3. Remove spark plug (using a spark plug socket). 4. Properly gap new spark plug (if applicable). 5. Apply sprark plug anti-seize compound on plug threads. 6. Install plug. 7. Aplly coil boot grease on the coils' rubber boot tips. 8. Reinstall coil.
May 22, 2010 | 2008 Mazda Tribute
No spark at plugs replaced distributer coil an
did you replace the coil wire?
and distrubtorcap and rotor?
Feb 24, 2010 | 1984 Ford F 250
Line trimmer does not appear to have spark. How do you test a coil wire?
you can connect a new spark plug to the spark plug wire and ground the spark end to the motor you should see a spark if not ajust coil to 010. from flywheel if no spark after that coil is bad get new coil
Jul 18, 2009 | Garden
Computers & Internet Logo
160 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
