Question about GE JVM1650 1000 Watts Microwave Oven
Shutdown suddenly checked the circuit breaker is ok   could it be separate fuse in the unit?
  • gunner33 Sep 01, 2008
    thanks for trying.I will attempt to check the fuse as per your suggestion
  • GE Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have black wires. You can ignore the ones with blue / violet wires in this case.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 01, 2008
  • William Miller
    William Miller Sep 02, 2008
    Why a rating before you try my solutions?
My Trager set on smoke and it reaches smoke temperature. The fuse is ok the control seems ok, circuit breaker has popped 3 separate outlets
Does the fan and the auger both work? There is a short somewhere. If those are GFI circuits it is tripping, it could be just a little dirty (greasy) at one of the connections.
Oct 13, 2017 | Microwave Ovens
Have had oven for 12 years and suddenly nothing happens. What to do because it is going to be hard to find a built in microwave oven to fit the size of regulat 30" oven.
Check the breaker. If OK, check the fuse on the circuit board and the power board, if its separate.CAUTION: Microwaves have LETHAL voltages in them 4000+ volts that can easily kill you! Make sure the unit is unplugged from the wall and that the HV Capacitor is discharged, BEFORE you touch anything
Mar 24, 2015 | In Microwave Ovens
No Power, No LED's. Circuit breaker OK
There is an internal fuse, however to access it the unit must come out. The outer case will need to be removed. The following link will take you to GE's website where you can get installation instructions. The fuse is available at ther parts site, but you can get a new on for less than a dollar at radio Shack. Take the fuse with you.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JVM1665DNWW
Mar 05, 2010 | General Electric Microwave Oven
The microwave is absolutely dead as if getting no power - circuit breaker is OK. Died suddenly...just nothing there when tried to use.
Possibly the internal fuse. Unplug unit, remove all case screws on the back of the micro. Slide the case toward the back and remove. Look for a glass tube type fuse, simular to automotive fuses of the past. It should be located near the controls. If bad, I have been able to find replacements at Radio Shack. If the fuse is good, I'm sorry, it's beyond my microwave knowledge level.
Jan 03, 2010 | Sharp R-1460 Microwave Oven
Does the rf375pxdw whirlpool range have a fuse or reset button? burners and oven does not work. there is power from the 220 plug into the range and the clock operates but not the 220. I checked circuit...
No reset buttons or fuses. Find the circuit breakers for the unit, it should be a double breaker with at least 40 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the range itself. Check for shorted and loose wires.
Dec 18, 2009 | Microwave Ovens
GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL DISPLAYS ARE ALL BLACK, CIRCUIT BREAKER NOT TRIPPED. The oven was actually working, then suddenly in the middle of warming the food, it did quit -...
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Nov 09, 2009 | GE JVM1190 Microwave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Nothing works, blank touch pad
before you replace a circuit board check the inline fuse on the unit if you take off the the front panel you usually can see the fuse it is a 20 amp fuse you will need an meter to check resistences across the fuse it should read read 1 to 2 olhs on the meter if that does not work then you need to check tstat on the megatron itself or the the cavity tstat more than likely it is the fuse
Mar 22, 2008 | Whirlpool MH7135XE Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
