Question about Epson Stylus 2200 InkJet Photo Printer
Ink pad woes
I read your cleaning instructions for the pads. Does this work on an Epson 2200? The ink pad doesn't look like how you described it.
Alan
    Guru:
  • 859 Answers
Sorry to be a few days in getting back to you. We had a death in the family and settling all the affairs has occupied most of my time for most of this past month or so. All is settled now, except for the memories.
As to your question, there is some variance from one maker to another and from one model to another.
I believe in your case, excess ink is carried out a flow tube to a reservoir and after printing a fixed number of times the Epson software gives you a warning message that the ink tank is full and to empty it.
Is this the case in your model? You are not seeing absorber pads?
When the print head cartridge is at rest a platform rises to seal off the print heads and prevent them from drying out. It is this platform that has the excess ink overflow tube that runs to a reservoir.
So, let me know if I'm spot on or way off base and if the later, give me a hint as to what you are seeing and what the problem happens to be. I'll be glad to help you get through this and if need be I can bring another expert into this discussion.
Regards,
Worldvet
Posted on Aug 29, 2008
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.ssclg.com/epsone.shtml
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Jan 09, 2013 | Epson Stylus C67 Photo Printer
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Epson SP2200 - yesterday - gave me a message that some of its parts are nearing the end of their service life. No specific parts were identified in this utility message. byclaudia@mindspring.com I'm...
The ink counters are full and need resetting, you also need the waste ink pads replaced.
This utility should reset the counters for you. Full instructions are on the download page, I reccommend you do read them.
Dec 13, 2010 | Epson Stylus 2200 InkJet Photo Printer
Both the red and green light are on and blinking.What is wrong with my Epson C60?
kiryakitsa1 You should download the SSC Service Utility as pineworks says. Read the instructions and warnings. Go to Reset counter protection and press reset. You may recieve a warning about replacing your waste ink pads. I have always reset the protection counter without replacing the waste ink pads and I have never had a problem. If you see ink drainage then you should replace the waste ink pads and then reset the protection counter. I have never had a problem with ink heads and I have done this many times.
Feb 07, 2010 | Epson Stylus C60 InkJet Printer
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
Red and green lights flashing alternately
Hi there.
Under each printers there is a pad, a spunch that holds all the wasted ink. This pad is probably full. you should locate where the ink pad is and change it or clean it. By cleaning I mean getting rid of all the ink from the spunch. After cleaning or replacing the pad you shoul run a utility to reset the protection counter. I use to have a all in one epson printer and did the same. I use SSC Service utility. it helps to reset the counter. After that, if that is the problem, your printer should work again.
Good luck
Mar 30, 2009 | Epson Stylus C46 InkJet Printer
Epson 2200 printer ink pads
First download this Epson utility to reset the ink counter:
http://inkjetprinterhelp.us/epsonSSC.html
Read the disassemble instructions on this link:
http://www.fixyourownprinter.com/forums/inkjet/35177
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 27, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson 2200 ink replacement light stays on
I had the same problem with the light black and light magenta as well. It took trying only one new cartridge with the light magenta before it worked.
The light black took 4 new cartridges before it worked. I had called the Epson support center on this problem and after going through suggestions they made that did not work, I told the guy I had another new cartridge on hand. He said to go ahead and try it. This time the printer worked. He took my name and address and said the other cartridges were faulty. Epson is sending me new replacement cartridges at no charge.
Dec 04, 2008 | Epson Stylus 2200 InkJet Photo Printer
Response to solution one Ink pad woes
There is a method to clear the counter and I think it is posted here somewhere. It is a sequence of keys on the printer control panel.
I'll see if I can find it for you.
WV
Aug 30, 2008 | Epson Stylus 2200 InkJet Photo Printer
EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Mar 25, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
99 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
