Question about Sewing Machines
Euro pro model 385W sewing machine
When we have it threaded the top thread keeps getting jammed up in the bottom bobbin if i redo the bobbin as shown in manual then the bottom thread will not loop so it will stitch
  • Anonymous Sep 11, 2008
    Hi I just sent this below thinking that it was the area for my questions, but I was wrong so I'm hoping I can get help this way!!!
    Hi FixYa,
    I'm fifi1076, and I'm having quiet a good bit of trouble with my sewing machine.
    I'm new at this site so I don't know if I'm doing this correctly or not so please
    forgive me if I do something I'm not suppose to do!!!!
    I copied this question from off of this site for I wanted to make certain that
    whoever answers my question will understand that all of the question
    doesn't pertain to my problem.
    "when we have it threaded the top thread keeps getting jammed up in the
    bottom bobbin. if i redo the bobbin as shown in manual then the bottom
    thread will not loop so it will stitch"
    This is the only part that pertains to my problem...... when I have it threaded the top thread keeps getting jammed up in the
    bottom bobbin......and I can't get it to sew at all....it won't do nothing.....the motor will just sit there and grind.
    If whoever can help me with this and can give me a solution I will be forever gratefull
    Thanks,
    Kay Nowicki
Hi FixYa,
"when we have it threaded the top thread keeps getting jammed up in the bottom bobbin. if i redo the bobbin as shown in manual then the bottom thread will not loop so it will stitch"
This is the only part that pertains to my problem...... when I have it threaded the top thread keeps getting jammed up in the bottom bobbin......and I can't get it to sew at all....it won't do nothing.....the motor will just sit there and grind.
Thanks,
Kay Nowicki
Posted on Sep 10, 2008
Bottom thread jams
Could be incorrect thread or needle size for the material, or old thread, blunt needle. or incorrect threading of the needle. Do you make sure the presser foot is raised when you thread it? :)
Jun 25, 2014 | Euro-Pro 1100
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have a euro- pro model 385x. Every time I try to sew, the needle jams and the bobbin is surrounded by thread. I have tried loosening the bobbin as well as tightening it but to no avail. I get a big...
The problem is likely the threading. Double check the threading, look twice or three times at the diagram. Even me, a tech sometimes threads a machine or serger wrong.
Derek
Jan 17, 2011 | Euro-Pro 473
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Sep 25, 2010 | Euro-Pro 9105 Computerized Sewing Machine
I keep having the same problem. I have the 7133 sewing machine and the top thread keeps getting stuck on the bottom. It's not the bobbin thread that does it but the top thread which gets caught on the hook...
Sounds like insufficient tension on the top thread. THIS may be due to variation in the thread itself or incorrect adjustment.
ALSO I recently found out that some bobbins have a metal core that can catch the thread as it goes over. The person recommended using the plastic bobbins that have smooth angled sides.
Nov 20, 2009 | Euro-Pro Shark 80 - 7133
Top thread gets stuck around bottom bobbin and jams machine
have you tried oiling it after you clean out all the dust and thread ends, you can take the feed dog plate off and clean under there as well. hope it helps
Jul 22, 2017 | Euro-Pro Shark 80 - 7133
How to oil euro-pro 373?
Have you tried flipping the bobbin in it's case, so that the thread comes off the top of the bobbin instead of the bottom. Some machines are sensitive to one direction of the bobbin thread.
Dec 04, 2008 | Euro-Pro 373 Mechanical Sewing Machine
Euro pro 385w problems
if your machine is like mine the bobbin is not filling right. My bobbin thread is very loose when it should be tight. I am also looking for bobbin solutions. If I wind the thread around the thread tension guide 2 or three times it keeps the thread tight going to the bobbin winder. I hope this helps
Jun 25, 2008 | Euro-Pro Easy Sewlution 385 Mechanical...
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
225 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
