How can i remove the 'this is not epson ink' from mmy printer to allow me to use other brands. It has been working ok but tonight it has decided not to work
By looking up the answer on the internet
Posted on Aug 28, 2008
How can I use non-epson ink cartridges in the Epson printer?
Yes and No. Non branded ink cartridges need to be properly programed to work correctly. If you are going to buy non branded, make sure you can trust the seller. Research the seller and you should be ok. Branded is always the best but also always more expensive and non branded always comes with a degree of risk.
Dec 03, 2015 | Epson RX595 Photo All-In-One Printer
My brand new EPSON ME101 flashes all lights. Not able totake any print outs.
If the printer is new, the cartridges may give less number of print outs with epson printer or the cartridges may not work at all. This problem may be because the cartridges has a resetting chip. This chip has a capacitor that is drained off over the years.
Feb 11, 2013 | Office Equipment & Supplies
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
How to test the epson stylus color 440 printer wthout a ink cartridge
You cannot test an Epson printer without both ink cartridges installed with a good supply of ink in them. All the printer will do is turn on the power. Nothing more. There is no way around this problem. They are built this way on purpose. The print heads in the printer can be ruined by allowing the printer to sit without ink cartridges in it. If you replace them, you might find that it no longer works depending on the amount of time it has sat without ink.
If you are considering purchasing a used printer that does not have any ink cartridges to test and see if it works, then all I can adivse is to be careful. You can get refilled cartridges from a company who sells them professionally for about 1/3 of the cost of brand new cartridges from a department store. Be careful using refilled cartridges though. It may void the printers warranty with Epson.
Hope this helps?
Nov 11, 2010 | Epson Stylus Color 440 InkJet Printer
My Epson Stylus Photo R265 is not allowing IJT Direct compatible ink cassettes to be used - they load into the printer OK. What can I do to make them work?
The compatable inks you use will depend on how old your printer is
Epson change their printer every few months changing the chips so if you have a very early printer you need the earlier chipped compatables
Feb 21, 2010 | Epson Stylus R265 InkJet Photo Printer
Compatible non epson ink not working
Epson has gone to great lengths to block compatible cartridges. Many of them simply dont work. Even those that do, you sometimes have to replace ALL of them. A mix of some Epson and some of another brand may give you the results you got. So you have to decide if you will continue to pay Epson's rip off prices or if you will buy a set of compatibles (which costs as much as one epson cartridge), do a one-time complete replacement, and then save money for the life of your printer.
I am using special reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink than Epson and cost me under $3. The ink is in a separate tank inside the main cartridge. When the ink is empty, I pop out the tank, pop in a new one, and the cartridge automatically resets to full. This is great because Epsons have a habit of reporting out of ink when there is still 10-15% of the ink left, so I can pop in an "empty" cartridge and still get more pages out of it. And I was able to use some of these together with some genuine Epson without problem, though the site says they can't guarantee this will work for all printers.
Jul 05, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
Epson R220 Only prints 80% of image
My Epson rx700 will not recognise any generic ink catridges and won't allow me to accept any of them like it used to. It used to offer the facility to accept generic catridges but suddenly has decided not to accept any.
May 31, 2008 | Epson Stylus Photo R220 InkJet Printer
Printing Blank Pages!
I just got the same problem with real Epson ink. There were some solutions posted under "not printing" that you might try. I haven't yet, but I am going to reload the printer driver tonight.
Dec 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Televison & Video Logo
Top Televison & Video Experts
