Question about Gateway GT4022 PC Desktop
Gateway screensaver option has disappeared from the display folder . how do I get this back.
  • 1 more comment
  • djcris009 Feb 09, 2009
    same problem here, crapway pc does not turn on, hate those guys, cuz they want me to pay 60 bucks in a call to crapway (gateway) to tell me where is the problem, i can't believe that,
  • Jason May 11, 2010
    Only way to do this is a registry entry that disallows the tab completely.
  • shrk79 May 11, 2010
    When you right click on desktop and select properties, is there a screen saver tab?
  • 2,229 Answers
I would first try a system restore back to the time it worked.
If that doesn't work, scan for viruses and other malware.
Posted on Nov 28, 2009
How do i set my timer for my screensaver-when my laptop is idle?
The option is under Screen saver options or there is an idle time shut off selection under Power Saver options as well. When you select your screen saver there is are specific options to customize how it shows and how long before it activates. Some screen savers have more options than others.
Oct 29, 2010 | Computers & Internet
Tip
My Pictures Slideshow screensaver
Make use of the Windows XP's My Pictures Slideshow screensaver for this purpose. Follow the steps:
Using Paint brush (mspaint.exe), create 10 or more images with a Black background in each. Open each image file and embed your company logo in it, in (place it in random areas, one in each image).
Create a folder for the image files you've created, and place the images in that folder. Assign this folder read-only permissions for all the users.
Now, configure the screensaver under your user profile. In the My Pictures Screensaver properties, do the following:
Set the folder where you've stored the image files
Set the interval using How often should the pictures change slider.
Uncheck all the checkboxes at the bottom of the dialog
Click OK and save the changes
Set the Screensaver Timeout to a preferred value in minutes
Test the Screensaver in your profile to see everything is fine
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Power saver mode appears on the screen and then shuts off display, after limited use leaving it blank. How do i fix it. using Windows XP?
You can open control panel and select power options in which you can preset the time necessary for screensaver, hibernate and switch off in battery as well as in power mode.
Once you ahve made the settings save and quit.
now check if the fault clears.
Sep 24, 2010 | Gateway FPD 1520 15" Flat Panel LCD...
How do i turn on the media center buttons?
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK. For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
Hope this helps.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen
Feb 10, 2010 | Gateway M-6866 15.4" Widescreen Laptop...
My laptop screen will go black. If I tap on the mouse or mousepad, it will come back on. Sometimes it stays on and sometimes on and off for awhile
I would check the Power features under "Display Properties", "Screensaver" tab, then monitor "Power" located at the bottom of the "Screensaver" tab. Check the settings located there and see if that helps.
Jan 02, 2010 | Gateway M320 XL Notebook
How do you change the back ground on a gateway netbook
If your Operating system is Windows 7, right click your current desktop, choose the Personalize, double click the Desktop Bacground, choose Browse, and browse to the folder that has the picture you want to use for the desktop background, click OK button. All the pictures on the folder is displayed. Click the check button on the picture you want to use and save the setting.
Dec 31, 2009 | Gateway LT2001u Netbook
Same problem on Gateway 7340
hi
just go to the screensaver setting.there you will find a button a power button.press the advanced settings.
there you will find many options..
one of them would be:when i press the power button of the computer...in that option just select shutdown..
if you find the solution useful plz rate me carefully
Jun 30, 2009 | Gateway 7320GZ Notebook
Dark display on monitor
go to control panel and make sure screensaver and hibernate mode is off.
Jun 22, 2009 | Gateway MX3560 Notebook
Screensaver want work
Go to:
Start >> Control Panel >> Display >> Select the tab ...Screensaver
Modify the settings of your screensaver there and also (enable - disable)
Oct 27, 2008 | Gateway Computers & Internet
Gateway GT4022 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
