Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer Duet model ghw9100lw
My 5 year old Whilrpool side-loading Duet washing machine will not spin or drain water, instead it makes a cracking/crunching sound as if it is trying but unlable. It seems that the pump ajacent to the drain hose it the culprit as it is where the sound of crunching is being made.
It the replacement of this pump very complicated or can I do it.
M.
  • marguerito Aug 28, 2008
    Thank you so much! No, there was no error code displayed and it seems that there was partial drainage but not enough to totally empty the inside drum. The noise is what prompted me to investigate. Thanks to your insturctions, I pulled out a lace doilie and a number of rusty straight pins from the trap. I ran a short cycle it it seemed to work, but I am not sure if I am imagining it, but the motor next to the clean-out trap is making a grinding noise. I am trying to figure out how to look inside the 'black box' to see some stripped grears or whatever they are called.
  • 5,911 Answers
Okay, it sounds like you could very well have something lodged in the pump impeller. You can check the pump and clean the reservoir to see if there actually IS something there, and to see if clearing it will enable the washer to drain. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow these instructions, you may get away without having to order any replacement parts. If you can hear the pump running, there may be a chance that the pump still may be operational. However, if something has been lodged in the impeller for a while, the pump may be damaged to the point where it no longer pumps like it should. The only cure for this is to replace the pump. The next link gives you step-by-step tips on how to do it:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Many of the steps are similar, but I try to be thorough. To answer your question, yes, this can be accomplished by the average do-it-yourselfer. You can find a replacement pump at searspartsdirect.com. Type in your model number as "GHW9100LW0" and the pump can be found under the "Pump and Motor" heading as item number 10 (part #8181684). The pump is sold as a complete assembly. I noticed that the pump is currently listed as being on backorder. It may take a couple of weeks for it to ship. If you need the pump sooner, repairclinic.com also carries it, but charges more for it. If decide to go this option, use the part number provided by Sears.
I'm still a little miffed by your symptoms. Normally, a drainage problem has an error code associated with it. Did the washer flash any codes on the front panel display? If so, you need to provide that information as well. If you require further assistance, please let me know. I hope this helps you.
Posted on Aug 27, 2008
  • Jeff Rockwell
    Jeff Rockwell Aug 28, 2008
    The motor next to your clean out trap is the drain pump motor. This is sold as a complete unit with a replacement pump. They can tend to be noisy, but if it is making an usually loud noise, you may think about replacing it soon. I gave you the part information and how to replace it in my previous post. This is a job that you can easily do without the assistance of a repairman. If you decide to replace this yourself, just follow the steps I've provided for you. If you need assistance at any point, please let me know. In the mean time, I'm glad you were able to resolve the drainage problem. Congrats.
    PS For future reference, besides checking pockets more thoroughly, make sure you use garment bags for small items. Socks and underwear have been known to find their way into the drain lines on this washer. I've had to unclog several of them.
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Whirlpool Duet Sport--won't completely spin out, leaves water in the tub. I cleaned out the drain filter, it kind of works for 1 load then goes back to not spinning out completely.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a whirlpool front load washer model number ghw9100lw my problem is that i am getting a f05 code i have changed the temp sensor and i am getting the same code i have unplugged the washer now when...
Check and replace
- Flowmeter.
- Water inlet valve
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Model # GHW9100LW on final rinse and spin water remains in washer, door locked and humming sound comes from machine....pause/cancel will not unlock door or start new cycle... what might be the problem?
Sounds like the pump is trying to drain the water but something is clogged in it or the pump itself is bad. Door wont unlock if machine thinks there is water inside. Remove front lower panel. pump is in center. Unscrew cap and remove attached filter. Be prepared for water to come gushing out once filter is removed. Clean filter and reinstall. If problem persists then the pump itself needs to be replaced.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 02 whirlpool duet GHW9100LW?
unplug for 5 minutes then plug back in see if it resets itself,also check the door switch on inside of the door on washer make sure that has a clicking sound,sometimes on some models if the door switch goes bad it will not spin or drain,let me know,thanks-mike
Jul 26, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
198 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
