Printer suddenly stopped printing - alarm light is on continually, even though I pressed resume button - also sounds as if it is trying to send paper through printer.
  • 3 more comments
  • gloriadsg Aug 27, 2008
    CANON MULTIPASS F60
    TURNED PRINTER OFF - NOTHING CHANGED
    HAVE DELETED ALL PENDING DOCUMENTS BEFORE CONTACTING YOU
    TRIED THAT - NO FUZZ OR ANY PAPER
    NO CHANGE OF PORTS
    Master:
  • 623 Answers
Click start
right click my computer
properties
hardware
device manager
?ports
scan for hardware changes
Posted on Aug 27, 2008
    Master:
  • 638 Answers
It may be because of the faulty cartridge.or some piece of paper is jammed inside.or due to faulty chip board.
if cartridge is faulty change cartridge.
if paper is jammed remove that piece of paper look care fully.
if nothing solves your problem then this is faulty chip board.do not get it repaired.as it would cost you near to new printer.sorry to say but if chip board error the printer is not more then a scrap.the canon printers have lots of this type of problem.buy hp printers that will never give you this type of problem any time.
rate the solution sir.
  • 1,586 Answers
Open the printer up and make sure that nothing is jammed inside (lint, fuzz, dustball, paper scrap, etc) in the gear mechanisms - anything like that can trip the warning light that you're seeing. I'm assuming that any paper coming through when it failed, came out intact, but a torn-off corner from an earlier page could have gotten worked around and jammed into the gears. Since you already reset the printer and deleted incoming print jobs, a mechanical jam is the most likely solution.
    Master:
  • 521 Answers
Delete all pending documents.simple
  • tech expert12 Aug 27, 2008
    replace the printer its much advisable.
  • 928 Answers
Turn off the printer for about 5 mins then turn it back on. Can you provide the model number of your printer as well as any error codes on the screen if you see any.
  • Thomas Lim
    Thomas Lim Aug 27, 2008
    Open and close the lid on the printer a couple of times and make sure you remove the USB connection to the computer first. After that turn it off again then turn it on. See if the Ink container will move. Also try to look if you see any paper stuck inside the rollers. Did you see any error messages on the screen?
My Canon MX310 alarm light is on - ink reservoir is almost full. I cleaned the reservoir and have tried the above procedure to clear the alarm but it hasn't worked. How do I clear the alarm?
Dear
You can reset the waste ink tank counter yourself. Be aware that this doesn't actually empty the waste ink tank itself but it does allow you to continue printing.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
Thanks.
Feb 22, 2015 | Canon Pixma MX310 All in One
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | Brother HL 1240 Printer
I have a DeskJet 5940 which was about to be thrown away and I thought I'd have a go fixing it. I tried, but it simply won't work. When I print something it pulls one paper nicely from the tray, feeds it...
  • Reset the product
    1. If the Power light is on, press the Power button (c01346625.gif ) to turn the product off, and then continue with the steps. If the Power light is off, go straight to step b.
    2. Unplug the power cord from the wall outlet.
    3. Plug the power cord back into the wall outlet.
    4. Press the Power button (c01346625.gif ) to turn the product on.
    5. If any lights are still blinking, service the product.
  • If the print-cartridge status light stops blinking after you reset the product, follow these steps to make sure the driver settings are correct, and then try printing again.
    1. Open the printer driver.
      • Windows 2000 : Click Start , point to Settings , and then click Printers .
      • Windows XP : Click Start , click Control Panel , and then click Printers and Faxes .
      • Windows Vista : In the Windows taskbar, click the Windows icon (c01364735.gif ), click Control Panel , click Hardware & Sounds , and then click Printers .
    2. Right-click the icon for the product, and then click Printing Preferences .
    3. Click the Paper/Quality tab.
    4. In the Paper size: drop-down menu, click the appropriate paper size.
    5. In the Paper type: drop-down menu, click the appropriate paper type.
    6. Click OK to close the dialog box.
    7. On the product, press the Resume button (c01421637.gif ) to continue printing.
    Also Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
  • Dec 17, 2010 | HP Deskjet 5940 Photo InkJet Printer
    Power went off when I tried to print
    Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
    Printer Does Not Start or Stops During Print Jobs
    Inner Cover was open when you started printing.
    Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
    Inner Cover was opened while printing is in progress.
    A page of print data being sent at the time of the error will be erased, so print that page again.
    The printer has been printing continuously over a long period.
    If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
    In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
    Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
    i_expl.gif Caution
    The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
    Out of paper.
    Make sure that paper is loaded in the selected paper source.
    Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
    If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
    If both paper sources have run out of paper, confirm the selected paper source and load paper there.
    Printing documents with plenty of photographs or illustrations.
    When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
    In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
    i_note.gif Note
    If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
    Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
    Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
    It is one of two things.
    a bad ink cartridge (the chip located on the gold part of it)
    or
    bad USB cable.
    IF you have a spare cable simply change them out.
    If you are refilling your cartridges, it is time to replace them.
    Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
    Here are all the flashing explanations:
    Two flashes: Out of paper or paper feed error
    Reload the paper correctly and press the RESUME/CANCEL button.
    Three flashes: Paper jam
    If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
    See Paper Jams
    Four flashes: Empty ink tank
    If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
    Refer to your Quick Start Guide for instructions on how to replace an ink tank.
    Five flashes: No print head installed/Defective print head
    Install the print head. Also, ensure that the protective tape has been removed.
    If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
    Eight flashes: Waste ink tank almost full
    The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
    Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
    My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
    hello!
    You will see 3 led lights on the printer. They will blink continously if:
    if the print cartridge status light is flashing
    -- check if the top cover is open, Close the top cover.
    -- there may be a problem with a print cartridge
    1. Verify that the correct print cartridges are installed.
    2. Check if a print cartridge is low on ink or improperly installed.
    if the resume light is flashing
    -- the printer may be out of paper
    1. Place paper in the In tray.
    2. Press the Resume button on the front of
    -- the printer may be ready to print the second side of a two-sided document
    1. Follow the onscreen instructions for printing the second side.
    2. Press the Resume button.
    if the power light is flashing
    -- the printer is preparing to print
    -- The light stops flashing when the printer has received all data.
    if all lights are flashing
    -- the printer may need to be restarted
    1. Press the Power button to turn off the printer, then press the Power button
    to restart the printer.Proceed to step 2 if the lights continue to flash.
    2. Press the Power button to turn off the printer.
    3. Disconnect the printer from the power source.
    4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
    May 06, 2008 | HP DeskJet 940c InkJet Printer
    Canon S 520 doesn`t print
    Two flashes: Out of paper, paper jam or paper feed error
    Replace the paper correctly and press the RESUME/CANCEL button.
    If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
    button.
    If paper has jammed in the printer, clear the jam, replace the paper in the printer
    One of the ink tanks is empty. Replace it.
    Six flashes: No print head installed
    Install a print head.
    Seven flashes: Defective print head
    Remove and reinstall the print head.
    Also, ensure that the protective tape has been removed. If reinstalling the print head
    does not resolve the problem, replace it with a new one.
    becomes completely full, contact a Canon service representative to have the waste ink
    tank replaced. Canon recommends to call for service as soon as this error occurs. Once
    the waste ink tank becomes completely full, printing will be no longer
    possible.
    Oct 19, 2007 | Canon S520 InkJet Photo Printer
    44 people viewed this question
    k24674
