Question about Kenmore Dryers
Kenmore 90 series
My sisters dryer had a problem of not drying as quick
so she pulled the vent line and cleaned out, and also tried pulling the front cover, in the process kinking the gas line, but not much.
after turning it back on the dryer started over heating and smoking.
could this be a thermostat problem?
  • 639 Answers
Dear friend,
ngfam at you service!
How about checking outside where the vent line exits the wall.
There is usually is a cover or door that keeps small animals from getting in and sometimes this gets clogged with lint and the dryer will bot dry! I removed my screen cause it was blocked with lint every week! perhaps the outside is blocked and when she cleaned out the vent line she caused some lint to go back into the dryer and smoking on the heat element or the gas burner if its a gas dryer!
I WOULD ADVICE AT THIS POINT TO STOP PLAYING WITH YOU SAFETY AN GET SERVICE OUT!
YOUR FAMILY IS WORTH MORE THAN A SERVICE CALL!!
BELOW IS WHO I USE!!!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 27, 2008
How do I remove the back of my My Kenmore 700 Series dryer
unplug the dryer,pull it out away from wall enough to disconnect the vent line,remove the vent line and pull the dryer out,remove the screws from the back panel that's it.what are you trying to do?
Mar 21, 2013 | Whirlpool LER4634J Electric Dryer
Our Kenmore HE2 dryer seems to be taking a very long time to dry clothes (120 minutes on Medium High to dry towels/jeans) . It is producing heat, but it also seems to be producing water/steam. The filter...
you need to clean out the vent line and the dryer.unplug the dryer,pull out the filter,remove the bottom panel and then remove the duct that the lint filter slides into and clean it out,vac out the inside of the dryer,if you have a shop vac you can blow all the lint from the back and then vac it up,make sure you blow off the motor,alot of lint gets built up around and inside it,pull out the dryer and pull off the vent line,if it's a long run i use a leaf blower to blow out the vent line,first go outside and make sure the vent is clear so when you blow out the vent line nothing is blocking the lint from coming out.this will take care of your problem,do this once a year and your dryer will last longer,you'll need less parts changed out over the years because the dryer won't over heat,you'll save on electricity,your clothes willl dry on time and most of all you won't have any fires
Sep 26, 2010 | Kenmore Dryers
Kenmore Model 110.68422700; the dryer cycles all the settings
when was the last time you cleaned out the dryer?you should clean the dryer once a year anyway so try this,unplug the dryer,remove the lint filter,take out the 2 phillips screws in front of the filter on the top panel.pull out the dryer,remove the vent line from the back of dryer and remove the back panel.on the left side you'll see the duct that the filter slides down into,take out the 4 screws that hold it in and remove it and clean it out,vac off the back of dryer,if you have a shop vac put it on blow and blow out the blower wheel and the heater and blow out the duct to get it clean.if the vent line is long i use a leaf blower to blow out the vent line,go outside first and make sure the duct outside is not blocked with any lint or anything and make sure the flapper opens freely.put it back together,except for the 2 phillips screws on top,with a screw driver pop up the top panel,there are 2 clips on each side that locks the top panel to the frame,just stick the screw driver in between the front panel and the top panel and pop it up,you'll see 2 5/16 screws one on each side around 4 inches down from the top on the inside,remove them and disconnect the door switch harness,use a screw driver to stick in between the harness to pull it apart to make it easier to get it apart,pull up on the front panel one side at a time and remove the front panel,vac out the inside of dryer,blow off the motor and blow all the lint from the back to the front so you don't have to pull the drum,if you know how to reinstall the belt take out the drum,the timer moves when the heat shuts down but if the dryer is loaded with lint the heater will not run correctly because of bad air movement and the clothes won't dry so try this first and let me know what happens
Apr 01, 2010 | Kenmore Dryers
Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
Mar 26, 2010 | Kenmore 62802 Electric Dryer
Have Kenmore 90 series elec. dryer...will start, but then cuts off and doesn't dry clothes. Trying to clean the lint out of it. We've taken all the screws out of the back, but can't get the back off!...
Hi-I just cleaned out mine. You take off the clamp that holds the exhaust duct from the bottom of the back of the dryer and you will be able to vacuum it out. Then you can remove the kickplate on the front of the dryer by lifting it hard and pull the top of it out. Then you can remove the lint trap holder once inside by unscrewing it, remove it and clean it out(take out the lint filter first). I vacuumed out the inside of the exposed bottom gently cause it was so full lint! Hope this helps!
Jan 23, 2010 | Kenmore Dryers
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
My kenmore electric dryer takes 3 times the normal time to dry clothes. It does eventually dry them though. I'm just using way too much electricity.
90% of drying complaints are due to problems with the vent. Try disconnecting the vent and run one load through it.If it dries properly clean out or replace your vent
Mar 06, 2009 | Kenmore 84052 Dryer
Wont dry very fast
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
Jan 30, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
