Question about Zanussi Washing Machines
I have just disconnected the inlet pipes on my Zanussi FJ1296 Washing machine but forgot to look which way round the go for putting them back - I can see no indication on the machine as to which inlet is for hot and which for cold - any ideas?
    President:
  • 1,462 Answers
Inner one is hot and outer one is cold.
to check after fitting hoses, put on rinse program and only cold water should come in. if hot water comes in then you have the hoses wrong way round.
Posted on Aug 28, 2008
Just got Zanussi 1050 just wondered if the clothes should come out warm after a once worn wash
No they shouldn't be hot. Sounds like you have the pipes on the wrong way round at the back of the machine. Should be red to red and blue to blue
Aug 11, 2010 | Zanussi Washing Machines
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
Replacing drum bearings, how to remove?
They come complete on spider assembly on some models..Check utube video. Or espares.co.uk for parts cost 1st...
Oct 07, 2009 | Washing Machines
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Zanussi nexus FL 1081
Sounds like your water pipes are on the wrong way round so its rinsing in hot water.
Nov 07, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
