Question about Beko 324250WN 28" TV
Beko tv push on no red light just a continuous clicking sound no picture nothing
I know its a long time but could be the high value Cap. careful though high voltages stored in these babies can kill you. even switched off for years.
Posted on Jan 17, 2009
What to test with voltage meter for non working Sony TV.
There may be an internal fuse that has burned out, but opening the cabinet on a TV of any sort is a dangerous thing to do if you're not sure what you're doing!! This needs to go to a repair shop -- or the dump. (It's probably cheaper to buy a new one than to have it repaired.)
Aug 27, 2016 | Sony Televison & Video
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Light on beko lcd tv goes from red to green and back to red without coming on
Main board fault. Shorted component/s on this board. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Mar 05, 2014 | Beko 17WLB450S 17 in. LCD TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
URC-22B doesn't work with my BEKO tv.
Check with this method. Manually turn on your tv.
Then push and hold the code saerch button until the light stays lighted release the button.
Push and release the device button you want to set TV.
Now you got to push and release the ON/OFF button until your device turn off when your device turn off stop and push and release the enter button for storage the code.
Warning: You may push and release the ON/ OFF button for almost 200 times.
Good luck.
Jun 12, 2009 | Televison & Video
Picture problem with Beko 32WLH530HID LCD TV.
did you ever sort this as ive got the same problem
May 27, 2009 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Don't work my t.v Beko model NR 21T75NXM
power ok.after 5min on .up and down pictuer dark.
Jan 19, 2008 | Beko 324250WN 28" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Beko 324250WN 28" TV Logo
166 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
