Question about Samsung 4 Channel Dvr
Trying to get hooked up
Can I hook up a digital video recorder shr-1040 to my samsung monitor sod14c ?
If yes can you show me how a picture how would be great?
Thanks Charlie
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Posted on Feb 20, 2009
Samsung SHR-1040 Digital Video Recorder
it sound like the system is locked up or your hard drive is going bad. write down all the info on the unit and reset and reprogram the unit. this may solve your problem if not you my need to send it in for repair.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
May 18, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
Starts recording then stops
The manual says that it can be replaced with almost any standard IDE drive but mine has a Seagate 160GB drive in it so may want to stick with original equipment. Other than tha, any drive SHOULD work.
Jul 02, 2008 | Samsung 4 Channel Dvr
Im actually ona magnzvox zc350ms8
use the set up button on your remote. Which brings you to the set up menu. Go to the very last option which is disc edit. then a new menu will come up and go to finalize disc, then a new menu pops up and just select yes. You have to have your remote to do this.....so make sure you hold on to it!!!!
Jun 18, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Samsung SMO 151QN need to purchase the proper recorder for this unit
We're using a Samsung SHR-1040 recorder with
a Samsung SMO 151 QN. It has more options than
needed ( has it's own camera ports) but it's cost
effective and records well. It has been in use since
July 2007.
Nov 26, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung shr-1040
it comes with a built in code it is 4321
Nov 20, 2007 | Samsung 4 Channel Dvr
Samsung shr-1040
Best to get a USB thumb drive and download the video needed to the thumb or flash drive. Put it on the computer and there you can use a program like Snagit to capture the best parts and save it for police. Saves a lot of wasted time
Oct 17, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Try this it will work:
Press and hold "ch1 and mode" buttons at the same time and hold for about 45 sec. This will change yoursetting to VGA . You can fined this info in your user manual on page # 6-13 see note at bottom of page for "HIDDEN KEY" shortcut's
It's a good system dont give up.
Aug 17, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung 4 Channel Dvr Logo
319 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
