Question about HP Photosmart M527 Digital Camera
Card format problems
When I turn in the m527 camera, a red screen appears stating thet card is unable to format. to press ok and after I do it states unable to read.. I do not tthink it is the sd card bacuse I tried several of them and thay all do not work.... what do i do.. The camera is practically new....the sd card will not work in the walgreens machine but the old one does, only the one that was in the camera at the time of this malfunction.. please help
  • Anonymous Mar 27, 2014
    Format as card but it won't let me
    Scholar:
  • 54 Answers
The first thing you will have to check the card. There is slot on the card that contains a switch. This will lock the card so that it is write-protected. This will cause the unsupported card error.
If the card looks fine, try a card reader just to confirm that the card has not been corrupted.
If the card is functional and you can read its contents from the PC or another SD-slot device, then the issue is your camera. The slot contains thin copper prongs that comes in contact the copper surface on the back of the SD card. If the prongs are bent or damage, then the camera cannot read your card.
Posted on Dec 10, 2008
When I turn on my camera, in the middle of the screen in a black box it says " DCF full error" what does this mean and how do I get it to go away? I have tried resetting my camera and formatting...
Hello
Thank you for using FIXYA!!!
OK, firstly let me state what exactly the error message you are receiving concludes to:
"The "DCF full error" occurs when you use memory card in your camera which is formatted in another camera. The error is the result of improper formatting of the memory card which leads to incompatibility of the card with the Samsung camera."
Now, i the resolution for this specific problem is to format the memory card in the Samsung camera.
I know you stated that you have already formatted the card, but you did not state if you formatted the card in your camera, or on your computer.
Try the above solution and let me know if the problem still persists.
Please do not hesitate to let me know if you have any further questions.
Kind regards
lock123
May 24, 2011 | Samsung S860 Digital Camera
When a memory card is put in the camera a red screen comes up stating "CARD HAS WRONG FORMAT. Press ok to format card." When I press Menu/OK the window says, "Unable to format." I can't even get to the...
Hello Mr rtautwein .
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 02, 2009 | HP Photosmart M425 Digital Camera
    Card has wrong format
    Not a solution, but after corresponding with HP customer service, they concluded that the problem with my M527 (see above) cannot be fixed. They offered to replace it with the same two-year old model for $99.99 which is much more than that model camera would be worth. I declined their offer.
    May 18, 2008 | HP Photosmart M425 Digital Camera
    Wrong format on HP M425
    Just fixed this problem on a M525 camera (same physical construction).
    Do a search with M525 and format.
    Feb 10, 2008 | HP Photosmart M425 Digital Camera
    Can't read memory card
    Try plugging the camera into your computer. Under my computer the camera should pop up as a new drive. Right click and choose format. If you have a card reader built into your computer you can simply plug the card into that and do the same thing. Either way you do it, that may help. Your card has been corrupted and the camera can not fix it. Windows may be able to fix it instead, it may not though. In the end you may have to purchase a whole new memory card for the camera. They can become corrupted and sometimes they get corrupted in a way that the device itself can't fix. I had a Multimedia Card get corrupted in my cell phone and the phone couldn't format it, nor could windows. Luckily there was a program for another type of cell phone that worked on mine that fixed it by doing a low level format of the card. This option isn't available to you on a camera, so you're somewhat limited in the ways you can repair the memory card. Peter
    Oct 04, 2007 | HP Photosmart M527 Digital Camera
    Sd card problem on photosmart m627
    Have you updated the firmware for the camera? The update is available on the HP website and is relatively easy to do.
    Sep 23, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
    Formatting memory stick.
    You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
    Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
    HP Photosmart M527 Digital Camera Logo
    167 people viewed this question
    Top HP Cameras Experts
    Fred Sops
    teddyboy
    Lawrence Oravetz
    Are you a HP Camera Expert? Answer questions, earn points and help others
