Question about Motorola Mobility RAZR V3
Storing phone numbers
Need simplest possible instructions for storing phone numbers
    Brigadier General:
  • 7,752 Answers
Enter the phone number, press store/save
Posted on Aug 28, 2008
I have a Sanyo Compander plus mode; CLT-1861 bouth 15 years ago. I lost the instructions on how to program phone numbers into it. Will it be possible to get them back................ Thanks. Carole
to store numbers.
1 press memory.
the talk indicator flashes.
the dialing buttons light for approximately 10 seconds.
2 dial the phone number you want to store.
3 press memory.
4 press a number ( 0-9 ) to assign a memory location number to the phone number.
a beep sound. the dialing button light goes off.the phone number is now stored in the hanset memory.
5 repeat step 1-4 to store other numbers or to change previosly stored numbers.
my name is jean( french for john) e-mail is morin.j2@videotron.ca
Sep 18, 2011 | Cell Phones
How to find previous call in phone no.?
Assuming you have Caller ID and an 824 system, you ought to look in the manual. You need to set up two buttons on the left side of the phone for CID-Indication and CID Selection (PROGRAM, Button, 96 and 97 STORE). We pick the top two buttons and store them in that order.
The small problem, is that you can't find BACK the numbers, but it will start recording the common numbers (last 300) from the time you do it until you get the 301'st call, then it will overwrite. (Chech your manual). Mine starts on page 158.
http://www.public.carl.airpost.net/Pana/TA-824/200_TA_OM_07-04%5B1%5D.pdf
Note that these instructions are for a U.S. KX-TA824.
Carl
Jun 17, 2010 | Panasonic KX-T7730 Corded Phone
Possible to add Caller ID?
it needs to be included in your phone service. companies offer different packages, perhaps you can purchase it by it's self.
Dec 03, 2009 | RCA 25423RE1 Phone
Bought Armitron #456974 and came without instructions
Simplest way is to use the instruction book that should have come with this watch. If you can't do it yourself, take it to a watch or jewellery store and ask them to do it for you.
Aug 21, 2009 | Bulova Watch
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
Nov 21, 2008 | Panasonic KX-T7630 Corded Phone
Spp n1000
1.Press PGM. The Talk/Batt Low lamp flashes.
2. Press SPEED DIAL.
3. Press one of the dialing keys (0-9) to store phone number. You will hear confirmation beep.
4. Enter the phone number you want to store (up to 20 digits)
5. Press PGM. You will hear a long confirmation beep and number is stored. Tall/Batt Low lamp goes off.
Do not allow more than 20 between each step of the procedure. If you enter a wrong number, press PGM and start over.
Jan 20, 2008 | Sony SPP N1000 Cordless Phone
Emmerson Phone Manual EM2248
Emerson (EMSEM2646WH) I need to know how I can set up the speaker phone and in a way that will be clear and loud. I lost my manual, could you send another one to me?
thanks
Nov 05, 2007 | Emerson EMSEM2646WH Phone
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
