Question about Dell E152FP 15" Flat Panel LCD Monitor
Blinking auto adjust in progress
A black box that says "auto adjust in progress" blinks now and then on my screen. The monitor has already been adjusted to the factory settings. Please help.
  • 1 more comment
  • Anonymous Dec 09, 2008
    I have the same problem with this model monitor and have almost tried everything and Dell technical support has not able to help me. I've changed lcd monitor and Vga cable, so i will try a tech to check the front panel.
    I will let you know. thanku
  • Anonymous Dec 10, 2008
    I've the same problem, the monitor tech claims the front panel can't be replaced and new monitor was needed.
    By the way....just thinking, I've the video card taken out many months ago and the pc was working fine, would this cause auto adjustment on monitor almost every site and keeps on flashing?
  • charlie1965 Jan 02, 2009
    I have the same problem! The MENU screen pops up and sometimes a LOCK ICON pops up. Could use a little help on this!
  • 220 Answers
The problem is with front panel switches which needs to be replaced.
Posted on Sep 12, 2008
Auto adjustment in progress keeps popping up
Try turning down the brightness on the monitor, sometimes this will fix the issue, if not the problem is in the inverter board and needs a professional to assess it further.
Mar 10, 2012 | HP w1907 LCD Monitor
Auto adjust in progress, want it removed
Your video card or monitor sounds like it might be malfunctioning. Have you tried another monitor? Does it show anything on the screen after turning on the computer? If it does then goes to "Auto Adjust" then try restarting and pressing F8 over and over until you get a menu. Then select VGA Mode. Change the screen resolution by right clicking on the desktop and clicking "Properties" then the "Settings" tab. Use the slider to lower the resolution and then restart.
Aug 03, 2010 | Microsoft Windows XP Professional
Monitor led is blinking green but screen is black. Unplugged and replugged all cables already.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement board:
May 19, 2010 | Dell E173FP 17" LCD Monitor
My monitor keeps saying auto adjustment in progress
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature. I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
May 11, 2010 | HP w2207 Monitor
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
if bad monitor start a post how to fix a bad monitor (endless answers)
Mar 20, 2017 | HP vs19 (Silver) 19" LCD Monitor
Auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Jun 09, 2009 | HP w1907 LCD Monitor
New computer won't start up stuck in auto adjustment mode
You can ask the computer tech what he did to fix you computer and post that info here.
Or, check out this tutorial on starting in Safe Mode to find and fix problems.
May 02, 2009 | Computers & Internet
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
1,564 people viewed this question
Alun Cox
