My Whirlpool stops in the middle of a wash to beep continuosly flashing F 02 or F09.
Could I get assistance as to what the problem might be and how I can fix it.
"F02" is a Long Drain error and "F09" is an Overflow Condition. The following two links explain both errors:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
The common factor with both links is the drain pump. There's a good possibility that you have something lodged in the pump. The next link explains how to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow the links and check the items common to both, as this could be the source of the two error codes occurring. It does not take much to damage the drain pumps in these washers. If you do find something in the pump, clean it thoroughly, and it still does not work, you will have to replace it. Let me know if it comes to this point and I can give you advice on how to order a replacement and how to replace it. I hope this helps you.
