Question about Canon PIXMA iP3000 InkJet Photo Printer
Told paper output tray closed when it is open
When trying to print getting message saying 'Document printing cannot be executed because the paper output tray is closed'. the paper output tray is open.
  • andyash Sep 09, 2008
    Canon Pixma ip3000 gives "output tray is closed" error even when it is open. I have to manually push the output tray down and keep it pressed to start the printing. The moment I release it it stops the printing and gives the same error again. How do I disable the printer from searching if the output tray is open or not?
  • dhakarosered Oct 25, 2008
    Output Tray is closed
Lift the tray a little...
Posted on Sep 13, 2008
Thanks. Will try this.
Posted on Sep 18, 2008
  • andyash Sep 19, 2008
    I wonder why Canon doesn't add an option in the printing preferences to disable the printer looking for an open tray.
This is a common problem with the Canon Pixma series, it appears that the flimsy switches on the internals of the machine are made of fragile plastic -- go figure. The solution is popping open the printer by prying at it (as there aren't many screws) with a few butter knifes of flat-head screw-drivers.
After popping the printer open you'll have to find a switch and permantently depress it somehow (even chewing gum would work) you can do this WHILE the printer is connected to your computer and attempting to print, this is what I've found to be essential to sometimes troubleshoot some of these problems.
Good luck.
4 Suggested Answers
  • 14 Answers
SOURCE: Document printing cannot be executed because the
there is a problem in the printer it is the carbon
Posted on Mar 08, 2011
  • 252 Answers
SOURCE: When ever I try to
Jilar,
Is the front tray down? That is the document output tray and it will detect an error if it's not down.
Posted on Mar 23, 2011
  • 60 Answers
SOURCE: Canon Pixma i4300. Front output
If you can remove the tray - have a look at it and it should come out without much force by pressing on the sides. If it comes out you may see the sensor inside that maybe is bent up and is not registering that the tray is open. If you see it you can bend it back down. You can also shoot canned air(with the tray in the out position of removed from the machine) and a piece of debris may come out. Use short squirts or the can gets very cold. All the office supply places and computer stores sell the cans of compressed air.
If none of the above helps, you can always communicate directly with Cannon at:
http://usa.canon.com/cusa/office?pageKeyCode=contactUsLanding
I have found them to be very helpful. Good luck..............................Pete
Posted on Jul 20, 2011
Every time I try to print to my Dell 3110cn printer, a message pops up stating "Load Tray 1 024965 Executive" Paper tray is full and inserted correctly...what do I need to do to make it print?
I would try two steps:
1) Check the "pending documents" for your printer and make sure the printer queue is empty - delete any pending document.
2) Check the printer settings and make sure the default paper type is not set to "Executive". You may also check this in the paper properties of the document that you want to print.
Apr 29, 2014 | Dell 3110cn Laser Printer
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma i4300. Front output paper tray pounced on by pet cat. Closed it up and opened it again When I try to print I get this message: "Document printing cannot be executed because the paper...
Jul 20, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Apr 01, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Cannon ip4300 does not recognize when printer output tray is open
The micro switch on the door may not be working. You need to fix it or replace.
May 16, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I can't print
Hi Paul.
Try lightening settings from Windows Control Panel>Printers and Devices>right-click XEROX>settings.
My CMYK and mono printers are SAMSUNG, last one was HP.
The menu screenshot should hopefully be similar to Xerox.
As only the XEROX is doing this, I suspect your XEROX specific user settings in Windows are set too dark.
The signature was probably done on paper, which is fibrous when magnified.
When scanned, the slight shadows between the fibers are converted to random white and slightly off-white pixels.
To the human eye it appears white, but when darkened, the not pure white pixels are visible, creating noise.
Besides setting darkness to normal or light, you could also try setting ECO to on. If the xerox has economy printing.
Nov 18, 2017 | Canon PIXMA MP190 All-In-One InkJet...
The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Mar 23, 2009 | Canon Pixma iP4500 InkJet Printer
Printer door open message
Apparently a solution has already been posted here: http://www.fixya.com/support/t345435-ip4300canon_printer
The author provides instructions on opening the printer and gluing the sensor into the "open" position (assuming that the sensor still works).
Apr 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
2,462 people viewed this question
old marine
old marine
