Question about Compaq CACHE BATTERIES
Battery does not charge
I own a Compaq M2015LA Presario Laptop, The battery it´s been dead for 1 year. I continue to use it only with AC adapter. The adapter finally went out. So I decide to order a new Battery and AC adapter as well. It powers up but does not charge the battery. Battery was good and new. I used the fully factory charged battery until dead, before I try to charge it for the first time. Any ideas????
  • 145 Answers
You may need to get a new one try that ok
Posted on Dec 13, 2008
Hi my laptop presario v3500 turn off after 10-30 minutes...my laptop battery is dead...i using power a/c only...what wrong with my laptop..i saw this model always have same problem...thnx u
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 20, 2011 | Compaq Presario V3500 Series Laptop...
I have a compaq nc6000 which wont boot up it trys to fire up then it goes off i have got to run but then it went back to this not booting up
Check and see if your DC connector is loose:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 02, 2011 | Compaq Presario Notebook
Satellite laptop battry don't charge
Take out the battery and only hook up the AC Adapter. If the laptop turns on then that means the adapter is working. Now hook up the battery and see if it charges. If it doesn't then that means the battery is bad.
Try another battery, if the new battery doesn't charge then that means that the AC Adapter is bad because its not putting out enough voltage to charge the battery.
May 31, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario c552us will not charge battery
THE COMPUTER DOESN'T EXACTLY CHARGE THE BATTERY. MAYBE THE ADAPTER FOR THE C502US ISN'T COMPATIBLE WITH UR COMPUTER, OR THE ADAPTER CONNECTION AT THE COMPUTER/ MOTHERBOARD IS FAULTY.
Jan 09, 2010 | Compaq Presario C552US Notebook PC
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Dead battery
you need the ac adapter to charg the battery
Apr 25, 2008 | HP Compaq Presario V6105NR Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Compaq presario does not turn on
Your battery is dead. You need to get a new power adapter. The battery isn't charging. The AC adapter went south. If the laptop is under warranty, you can get one from Compaq. Or, what I would do is shop on the internet and order one. Whats the numbers on the ac adapter? I'll help you find one.
Jun 30, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
103 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
