Question about Microsoft Standard Wireless Optical Mouse
Wireless standard optical mouse - pointer moves to upper right corner???
Suddenly, after like 2 years of perfect function my mouse-pointer jumps to the right (upper right corner most oftenly) with no reason. Its often when I left-click, but also when just moving the mouse. Tried replacing batteries and so on, but still the same. What can it be? Using a proper mouse-pad that have worked for ages.
  • 1 more comment
  • nskodali Sep 10, 2008
    Wireless optical mouse pointer jumps to the top right hand corner of the screen. I replaced the batteries and cleaned the lens but proved to be of no use. Please help. Thanks.
  • johasven Sep 25, 2008
    Yeah, I could have figured that out also ;)
  • Anonymous Mar 28, 2014
    suddenly touchpad mouse not working properly; the pointer keeps moving. This coincides with wireless internet access problem
Replace your optical mouse that's common problem with optical..
Posted on Sep 25, 2008
Where can i find the driver for my Bornd Mouse
Try this
Feb 07, 2015 | BORND M120 2.4G Ultra-Silent Wireless...
How to make a optical mouse work better?
Your mouse is an important part of your computer system, and when that mouse has problems it is important to get them resolved as quickly as possible.
There are a number of things that can cause a mouse pointer to behave erratically, and it is important to work through each of those possible causes one by one.
Change the batteries if you are using a wireless mouse.
The batteries in a wireless mouse will generally last a long time, especially if you use rechargeable batteries.
But once the battery power begins to decline, the batteries will lose power very rapidly.
If you are using a wireless mouse and the cursor begins to stutter and jump, chances are that changing the batteries will resolve the issue.
Move the wireless transmitter to another USB port.
Problems with the wireless transmitter can cause the mouse pointer to stutter and jump. Moving the transmitter to another port will often resolve this issue.
Right-click on the "My Computer" icon on your computer's desktop, and choose "Properties" from the menu.
Click on the "Hardware" tab, and click the "Device Manager" button.
Navigate to the mouse entry in the list of hardware devices, right-click and choose "Update Driver" from the menu.
Allow your operating system to search for and install the most recent driver for your model mouse.
Clean the mouse surface thoroughly if you are not using a mouse pad.
If you are using a mouse pad, shake any dust or dirt off of it to make sure the surface is perfectly smooth.
Any imperfections in the surface could cause the mouse pointer to behave erratically.
To clean the mouse surface, hold a clean cloth over the opening of a bottle of isopropyl alcohol and soak the cloth.
Then, go over the entire surface with the alcohol-soaked cloth and allow the surface to dry before attempting to use the mouse again.
Click on the "Start" button, and choose "Control Panel" from the menu.
Double-click the "Mouse" icon, and click the "Mouse Pointer" tab.
Adjust the speed of the mouse.
If the mouse speed is set too fast, it can cause the mouse pointer to stutter or hiccup.
It may take a few tries to get the speed just right, so just move the slider and test each new setting
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Hope this helps
Nov 04, 2012 | Computers & Internet
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I have microsoft bluetooth optical mouse 4000 it suddenly stopped connecting to the receiver, as I cannot move mouse anymore
Just to clarify, this is a wireless optical mouse, right? Please try the steps below:
1. Use fresh batteries.
2. Make sure that the mouse is turned on.
3. Check if there's a connect button on the wireless receiver and underneath the mouse. If there is, try holding down the two connect buttons at the same time for five seconds and then release them both.
4. Try moving the mouse.
5. Make sure that there are no possible wireless interference between the wireless receiver and mouse like the base of a cordless phone, cell phone etc.
If same problem occur after doing the steps below, then you may want to contact the manufacturer for RMA. This Microsoft 4000 has a three year limited warranty.
Thank you!
Nov 11, 2009 | Microsoft Wireless Optical Notebook Mouse...
Micro soft Model 1056 wireless mouse. When system is kept on for long duration the mouse pointer is not functioning. Please guide if any down load is required.Thanks Raj
I am currently downloading software for this problem. Just go to the download software link and select your mouse type and follow the steps.
Jun 11, 2009 | Microsoft Standard Wireless Optical Mouse
Mouse Cursor Jumps to the right of the screen
Have you tried going into the control panel - mouse - pointer options - motion speed (slower) and experiment with pointer precision check box? Try it, see what that gets ya.
May 05, 2009 | Dynex Wireless Optical Laptop Mouse...
Dell d600 mouse pointer jumps into corners if working on documents etc.; maybe if the system stores data in the cache or ram, the cursor wether jumps into the left down corner or moves slowly in directon...
What the issue is, is the eraser head mouse in the enter of the keyboard. When you type, it's putting uneccessary pressure on it, and it makes the pointer move. The only solution I know for this is to get the updated ALPS driver for the mouse, and disable the eraserhead (The updated driver gives you an option to do this), thereby using only the touchpad mouse.
Mar 15, 2009 | Dell Latitude D600 Notebook
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Feb 16, 2008 | BenQ M310 Wireless Mini Optical Mouse
Microsoft Standard Wireless Optical Mouse Logo
338 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
