Question about Frigidaire PLEF398AC Electric Kitchen Range
Burner will not turn off
The small, inner burner on my smooth top frigidaire gallery range will not turn off. Please help
  • 1 more comment
  • Villeman Aug 28, 2008
    i received advice for a dryer---i asked for assistance with a smooth top range. Duhh
  • nw6644 Dec 22, 2008
    I just had the same problem this weekend. I had to remove F7 wire from terminal on surface unit control to keep the burner from staying on. Did you ever get this repaired?
    Bad Bob from VA
  • ataxsv May 11, 2010
    my rf element will not turn off. What part if any should i look into?
    Model # PLEF398ACA
    Serial # VF20703913
  • 639 Answers
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
UH OH, This is dangerous !
Waste no time and call factory service!!!!!!!!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
  • Neil
    Neil Aug 29, 2008
    Dear Friend,
    I was talking about your cook top and accidentally typed dryer!
    I do this all day and sometimes it's easy to type O......
    A&E Factory Service
    1(800) 905-9505
    If this appliance is 10 years old or more do not spend any money on it!
    Bless you,ngfam1
Can I install a downdraft vent for my range?
I think you will find it to small to fit behind the range top
May 26, 2014 | Kitchen Ranges
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Oct 14, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
121 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
