Question about Whirlpool GEW9250P Electric Dryer
Whirlpool electric dryer
How do I open up the dryer to clean the lint on the inside?
  • 1huggie1 Aug 29, 2008
    I was trying to get inside the dryer to clean around the drum.
    Thanks......i
  • 639 Answers
1huggie1
ngafm1 at your service,
More tan happy to assist you!
Pull the dryer door open with your right hand at the handle finger insert that is on the left of the glass and at the bottom of the opening is a plastic filter that has the words, clean before each use!
Which you pull up and out!
Hope this helps you!
Bless you!
PS. PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 27, 2008
  • Neil
    Neil Aug 30, 2008
    1huggie1
    WHAT is the reason you think you need to clean lint inside the dryer?????????????????????
    There is no need to get inside for lint!
    Any lint that falls back inside Will blow out the exhaust pipe leading out the wall or burns off!
    That's why it is so important to clean the lint filter before every load!
    Who told you to open it and look for lint inside!
    Pull
    Bless you!
The circuits are on and there is electricity coming out of plug in, what else could be wrong
when the dryer is run is it warm inside when you open it ? If it is try cleaning the vent tube and make sure its not clogged with lint if the dryer is cold inside you probably need a new heating element.
Jun 03, 2014 | Whirlpool WED6200S Electric Dryer
Dryer dont get hot
Try cleaning all the vents inside the dryer all the way to the outside. Be sure and clean around the blower wheel lots of things get in where the blower is pencils nails everything. They will block the wheel so it can't turn. Also vacuum the lint out of the motor. Lint most likely the problem. Hope this helps.
Nov 22, 2013 | Whirlpool Dryers
The dryer still runs and the drum is turning. No heat. Yesterday I did notice the outside of the dryer got very hot for a while.
The thermal cut-off has blown open due to the high-limit thermostat failure to cycle off in order to regulate the heating element temperature as the noticed extreme dryer temperature indicates. These two components are wired in series with the heating element as a safety measure to cut power to the element should the dryer temperature go extremely high like your case.
Disconnect power then make sure the lint filter is clear, the vent system is not restricted, and the inside of the cabinet is clean. A vacuum cleaner may be used to extract lint built up inside the dryer cabinet particularly the bottom. Replacing both the thermal cut-off and the high-limit thermostat is a must but only after the all areas mentioned are cleaned.
Click on the links below for more troubleshooting and repair details.
Whirlpool and Whirlpool-made Electric Dryers (With Removable Back Panel) Not Heating
Whirlpool and Whirlpool-made Electric Dryers (Without Removable Back Panel) Not Heating
Jun 19, 2011 | Dryers
No lint in the lint filter
Check air flow out of unit and ensure you do have some foreign object stuck in the blower wheel. UNPLUG unit, and clear out exhaust tube from dryer. Have a professional clean house vent if you cannot see where the vent exits the house. It is common on Whirlpool, top of cabinet vent opening to have objects fall into the lint screen opening and restrict airflow.
Mar 28, 2010 | Whirlpool LER5636P Electric Dryer
Clogged lint inside dryer exhaust
there is a vent cleaning kit that can be baught at lowes or home depot and comes with attachments to get down inside the lint trap to be vaccumed out.
you can also lift the lid and remove the front panel and get to the trap area
Mar 28, 2010 | Whirlpool LER4634J Electric Dryer
How To Open Bottom of Dryer
Take the back cover off and there is a compartment that hook to the hose, with the right tools you can pull the compartment out and clean it to include other parts showing. hope I helped allittle.
Mar 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Cleaning Whirpool Ultimate Care II
once that you have lifted the top up you can remove the two screws that are down inside the frount panel about three inches, pull out on the frount panel and swing to the side, if the lint buildup is large then check the vent to the dryer for any kink a shop vack works great for this chore
Feb 18, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Electric Dryer 4yrs old, not drying the load completely
The sensors are two metal strips inside the drum. They are on the right side just behind the filter. They are silver colored and have a slight curve to them. You cannot see them unless you put your head inside the drum. I clean my sensors with a non metal pot cleaner like 3M Scotch Brite. These sensors also fail if you dry silicon backed carpets.
Jan 20, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool GEW9250P Electric Dryer Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
