Question about Legacy 4CH 1000W RED AMP Car Audio Amplifier
Legacy 1470 smoke prob.
Hi i have a la1470 i plug it in just the cables and it starts smoking however the powerlight is still on and the protection light isnt why? and Normal?
thanks
  • 631 Answers
If it begins to smoke with only the B+, ground and remote connected, the power supply transistors have likely failed.
The protection light generally won't come on if the power supply is blown because the supply must be working for the protection circuit (which protects the output transistors) to engage.
The power light may be connected to the B+ side of the power supply. If that's the case, the power light will illuminate even if the amp is inoperative.
Let me know if you have any other questions.
Posted on Aug 28, 2008
Misfires white smoke
head gasket would cause over heating and possible white smoke, your problem sound like the m.a.f. sensor needs replaced
Sep 08, 2013 | 1999 Subaru Legacy
Mass oil use and major blue smoke.
a common part over looked when a turbo is bad the drain tube gets plugged and oil cant drain
Oct 07, 2012 | 1996 Subaru Legacy
1996 Subaru Legacy GT - Twin Turbo, manual trans: started spitting a lot of white smoke out of the exhaust. It did that when the car started then seemed to be ok when in idle but when on take off and...
Expect to hear your head gasket needs replacing, at a minimum. White smoke means it's burning coolant. How much it will cost I can only guess, but usually a head gasket repair- a few hundred dollars-it's pretty time consuming and labor intensive, especially with all the turbo stuff that could be in the way. Good luck.
Apr 06, 2012 | 2012 Subaru Legacy 2.5i Sedan 2.5L 4-cyl....
My 1995 legacy is shooting oil on the engine and smokes while driving
hi check for a worn oil line/seal around engine causing oil to spray and burn on hot engine, possibly start up and when pressure gets up have a look where its comming from
Apr 11, 2011 | 1995 Subaru Legacy
I HAVE A 1998 LEGACY OUTBACK NO SMOKE NO SWEET
have you got heat in the car,what im saying is when you turn on the heater inside the car what happens?im not getting your drift,but get the thermostat checked out sounds like its not letting the coolant flow.adrian,,,,
Jul 21, 2010 | 1998 Subaru Legacy
Subaru Legacy White Smoke
smell the exhaust first, if it is sweet smelling, it may be the headgasket.
Jun 26, 2009 | 1999 Subaru Legacy
Smoking amp
The only way you'll know is by hooking it up and testing it. Amps should not smoke, so there's a pretty good chance you fried it.
Jun 16, 2009 | Legacy LA838 Car Audio Amplifier
B4 blowing plooms of smoke
Assuming that the Smoke is White or Black, You are gonna have to get an Overhaul on that Motor.
Jan 04, 2009 | 2000 Subaru Legacy
Legacy 4CH 1000W RED AMP Car Audio Amplifier Logo
101 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
