Question about Dell 924 All-in-One InkJet Printer
How to refill?
I have just attempted to refill my ink cartridge for my dell924 printer.is it as easy as pulling back the label,injecting the ink into the hole on top of the cartridge then covering hole with label again,or have i just made a right mess of it?
    Scholar:
  • 98 Answers
Yes its same but do not insert the needle very much in the cartridges and do not over full the cartridges as it will leak and not print properly.
thanks.
Posted on Oct 23, 2008
How can I make printer recognize refilled cartridge on lexmark prevail pro 705
Refilled cartridges will not reset the ink levels. The printer will still recognize it as empty.
Please be advised that refilled/remanufactured cartridges could damage your printhead and will not be covered under warranty.
Nov 27, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
How can i refill my mp540 cartridge?
First, purchase these refillable ink cartridges from a third party company: http://www.dhgate.com/canon-mp540-mp620-mp630-refillable-ink-cartridge/p-ff80808129a751870129aff7bc723664.html After that, head to staples or go online to order the ink. The cartiridges that come with the Canon or the retail ones may or may not work because of the microchip inside of each cartridge. You can try to refill those by removing the label off the top, and you should see a hole or two to poke a needle into. Once you purchase a refill kit it should come with something to inject the ink with.
Feb 28, 2011 | Canon PIXMA MP540 All-In-One InkJet...
I need to know how to refill my ink for my nx110 printer
The ink cartridges used in Epson's Stylus line of printers are very similar to the ones used in its other printers. A handful of cartridges--like the S020034, S020047 or S020049--may require a slightly different refilling technique, but they all basically entail opening a fill hole in the top to run down into the ink chamber within. Once the chamber is accessible, you can use a basic refill kit with a syringe bottle to refill the chamber, as with most printer-ink cartridges.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
1. Hold the cartridge upside down so the outlet holes to the printer paper are on top. Cover each hole with a piece of tape, then turn the cartridge right-side up.
2. Make a hole in the top of the cartridge above each ink chamber. For most cartridges, simply poke a hole through the label with a toothpick. With cartridges like the Epson Stylus 34 (the casing of which is black), pull back the label to reveal the filling holes and puncture the seal of each home. For the 47 or 49 color cartridge, drill a 1/8-inch hole in the shell between the label and front edge.
3. Determine which color of ink is in which chamber (if you're refilling a color cartridge). The toothpick used to puncture the hole should draw out some ink to show you. If you have a cartridge in which you punctured the label directly, the order of the color chambers is usually cyan, magenta and yellow. If you created the hole in another way (like with the 34, 47 or 49 cartridges), the order is usually magenta, cyan and yellow.
4.Fill the syringe bottle with 5ml of ink. Insert the needle in the filling hole and inject the ink. There may be a sponge inside the chamber, so make sure the needle goes all the way through to the bottom. The 34 cartridge takes up to 12ml of ink.
5. Tape over the fill holes you created. If you drilled the holes, plastic plugs (like the ones included in a refill kit) can work as well. Leave the tape on the outlet holes as you replace the cartridge in the Epson Stylus printer.
6.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
I don't know how to refill
Hi Good day!!!
1. Spread newspaper or paper towels on a table to create a workspace protected from spills and accidental leaks. Set the cartridge on this workspace.
2. Remove the label on top of the cartridge. Use a razor to peel up one corner, if necessary, then peel back the rest.
3. Fill the syringe from your refill kit with between five to 10 milliliters of ink. Match the ink to the color listed on the cartridge.
4. Insert the syringe needle into one of the holes on top of the cartridge. If there are no holes in the cartridge, you must create one. Use a thumb drill (also included in your refill kit) to punch a small hole through the plastic.
5. Insert the needle into the cartridge. Inject the refill ink into the cartridge until it is full. Ink will bubble up around the hole when the cartridge is full. Fill the cartridge slowly to avoid mistakes and spills.
6. Place the cartridge back into the printer. Wait at least a few hours before printing. Some refill kits recommend waiting 24 hours before using the printer. Print a test page when the cartridge is ready.
Oct 26, 2010 | Computers & Internet
Where do i inject the ink in my cartridges on a lexmark printer. i need to refill both cartridges. i have the black and coloured ink, and the syringe, however i dont know where to inject.
Usually the refill kits come with instructions that cover many cartridges.
A lot of the lexmark's use HP style cartridges and those often you lift the label to access the fill holes.
FILL SLOWLY and do not over fill. Usually the cartriges hold so many ml and youcan measure that on your syringe. Knock off a few ml from what they say the cartridge takes.
Nov 11, 2009 | Lexmark X2500 All-In-One Printer
Swap black inks with Epson 9800
By using Colorbyte's Imageprint software and their 'Phatte Black' cartridge....
www.colorbyte.com
I have not purchased it myself quite yet but im good friends with an Epson R&D guy who tested their system and highly recommends it.
Mar 20, 2008 | Epson Stylus Pro 9800 InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
