Question about Labtec (9115290914) Mouse
Erratic Mouse Pointer Movements
The mouse pointer moves erratically, opening and closing windows, and just having a mind of its own. This happens especially when I connect to the internet (I use both Internet Explorer 7 and Firefox 3.0.1 browsers). I have scanned all files with antivirus programs (mcaffee) but the problem remains. The problem seems to disappear sometimes, but reappears when I start another browsing session. Any suggestions to fix this problem?
  • hsmshoe May 11, 2010
    The mouse pointer moves erratically, freezes up opening and closing windows, and just having a mind of its own. This happens especially when I connect to the internet.
5 Suggested Answers
  • 5 Answers
SOURCE: labtec wireless desktop.
Could be radio interference from somewhere. I tracked my similar mouse problem down to emissions from the ethernet adapter that connects over the house mains wiring. Try the using the mouse close to the receiver, if it works ok interference is likely.
Posted on May 04, 2008
SOURCE: Inspiron 1525 Touchpad has a mind of its own
I have had the same problem.  This may sound strange, but try the following:
Switch off the notebook.
Remove the battery and keep the on off switch pressed for >5 seconds.
Replace the battery and start the computer again.
The problem should then be resolved.
Posted on Apr 29, 2009
SOURCE: Erratic pointing
After experiencing the same issue for a few frustrating hours, I read here the theory about the required distance accuracy between the sensor and the surface.I used to be able to use mice (any brand) on a simple piece of paper or directly on (wooden) surfaces. Not with this "laser mouse..." I was about to try the "tape-with-a-hole" solution, but before trying that I simply threw a heavy, thick magazine with a glossy back-cover on the table and tried again. Worked like a charm. The heaviness of the magazine (I think) lent the "flatness" which I believe is the real required solution. I'm not sure if the glossiness played a role here...
Posted on Jul 07, 2009
cowboytech
  • 69 Answers
SOURCE: Why does my wireless mouse seem to ake the cursor go crazy?
Several things can cause this. If you're using the mouse on a reflective or glass surface, the laser light underneath will dance all over the place, and it doesn't take much to make the mouse pointer go crazy. Put a standard mouse pad under it. If it's still doing the same thing, then replace the batteries. If both of those don't work, replace the mouse.
Believe it or not, if another mouse does the same thing, you probably have a malware or virus infection. There are some 30 or more common viruses that are really just nuisance type programs that intentionally make your computer (especially the mouse) do some very strange things. I guess that's some geek's idea of humor.
Posted on Jul 17, 2009
Laptop pointer erratic
There is a setting in your Control Panel/Mouse, which is a check box to enable it to hide the mouse pointer when not in use. Disable that and see if it helps.
Sep 05, 2014 | Dell Inspiron 1545 Notebook
Windows 8.1?
Not sure what you mean but a possible problem with erratic mice is the mouse pad. A coloured pad sometimes reflests the light in an erratic fashion that causes the pointer to do unexpected things. Try it without a pad or one with no patterns.
Aug 31, 2014 | HP X4000b Bluetooth Mouse
Pointer has erratic motion when moving mouse
try changing the batteries
or change the surface the mouse runs on
hope it helps
Feb 21, 2011 | Logitech Cordless Mouse
Good Day' I have recently purchased a new Toshiba Satellite Laptop. The operating was Vista, so I changed it to Windows 7. Now whenever i'm typing the cursor just goes wherever it likes,...
Hi Barry,
You open up Google and search for touchfreeze. It fixes erratic cursor movements. Download and install it and your mouse pointer will stop moving as it wills.
Good luck!!!
Jul 22, 2010 | Computers & Internet
How to stop razer pointer from moving
Stop moving the mouse.
Ok seriously, if a laser mouse is on a reflective or glossy surface such as a varnished wood desk or a magazine the mouse can do erratic things...
Feb 17, 2010 | Razer Pro Solution V1.6 (RZPROSV16)
Mouse continually skips around. I changed batteries, reset it and everything. What's wrong?
You have the tracking speed set too high.Go to 'start'-'control panel'-'printers and other hardware'-'mouse'.After opening mouse you'll see "pointer options",click and you'll see "pointer speed".Move the speed down from fast to slow until you can see it easily.The other thing is if you don't have enough RAM memory it won't be able to keep up with simple hand movements.Click "start'-right click"computer"left click"properties"and up will come what you have for a computer will be displayed.Near the bottom of the page will be RAM,to it's left is how much you have.XP you need at least 512MB(1GB is better-up to 3GB best)Vista 1GB minimum,up to 6GB with Vista x64.Adding Ram is the easiest way to speed up a sluggish machine.Please re post if you'd like to get into changing setting for best performance.
Dec 30, 2009 | Dynex Wireless Optical Laptop Mouse...
POINTER FREEZES THEM MOVES THEN FREEZES DRIVING ME NUTS. THANKS
When this behavior is observed when using a Logitech product withinWindows® XP, it may be caused by a feature within Windows called"enhanced pointer precision". This feature may conflict with Logitech's software, causing the erratic movement. Enhanced pointerprecision became available in Service Pack 2 and therefore is notapplicable in any version of Windows® XP without Service Pack 2installed. For more information on enhanced pointer precision,please click HERE. If this link does not work, then you should go to Microsoft and search for Knowledge Base article 895550.
Please see these articles from the Logitech database for possible troubleshooting tips as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
Troubleshooting: Erratic Cursor Movement in Optical Mice and Trackballs
Mouse cursor is uncontrollable or behaves erratically
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Interference with Cordless Products
Download latest version of software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 27, 2008 | Logitech Cordless Mouse
Jerky mouse
Try using a different Mouse Pad or surface. This is a cause of jerky and erratic mouse movement.
Hope this is of some help. Bud
Oct 07, 2008 | Logitech Cordless Mouse
Acer "aspire 3680"
hi dear
What happens if you unplug your microphone?
No, I'm not joking. Several users have found that erratic mouse movements
were caused by their voice-recognition software trying to make sense of
random sounds coming in through the sound card, and feed those signals to
the mouse driver.
If that's not it, then fall back on the old faithful: make sure you have
the latest and best driver for your mouse. If you tell us the make and
model, there's a good chance that someone here will recognize it and know
which driver you should be using. (Of course, it could be a small defect in
the cable, too.)
Mar 22, 2008 | Computers & Internet
Erratic behavior
I just sprayed my dad's lens cleaner on one end of a Q-tip to clean the lens of the mouse and dried the excess fluid with the other end of the Q-tip. WORKS GREAT :)
Nov 10, 2007 | Targus AMU18US Mouse
Labtec (9115290914) Mouse Logo
399 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
