Question about Acer TravelMate 2500 Notebook
I have an acer Travelmate 2500
I have just installed a standard layout keyboard with a number pad on the far right.
when i remove the usb keyboard, the Std built in keyboard will not function propely, it seams that it does not have the right config for the "Fn" button.
every button that has a "second function" it defalts to using the second function instead of the qwerty layout.
any ideas?
    Brigadier General:
  • 5,158 Answers
Is the second function numbers ?
Robert
Posted on Aug 28, 2008
Where is the WLAN switch on the Acer EXTENSA 52325
i Found this on product manual..hope this helps.
ACER
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire 5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa 2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
Sep 09, 2011 | Acer Aspire 5100 Notebook
My acer travelmate 2500 overheats when playing games
The cooling on the Acer Travelmate 2500 is worse than most because it contains thin copper heatsink fins which grab the dust as it flies past. Great for getting rid of heat; terrible for getting rid of dust.
prise off the two corner pieces that cover the hinge for the screen. Underneath there are two screws. Remove these, then peel away the keyboard and the plastic covering. There you will see the fan system. Four screws (on springs - careful) will have this away but be aware of the power cable which is tucked in behind a piece of metal. At all times be careful not to damage the keyboard ribbon cable which is usually pretty fragile.
Another few screws (tiny ones) will have the top of the fan off then you can clean and put it all back together. The result: a laptop that actually blows air through and cools what it should.
Kindly rate if this helped Regards
May 13, 2011 | Acer TravelMate 2500 Notebook
Trying to enable the wi-fi on my acer 3693WLMi
install an application called 'Launch Manager' That will help. You didn't say what model? Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
If you don;t have the drivers go to the Acer site and download them, and install.
Feb 27, 2010 | Computers & Internet
My Acer TravelMate 4672WLMi laptop keyboard diplays the @ key when shift inverted comma is pressed and the reverse with the @ key. The backslash key produces the # key. Any suggestions James South Africa
Hi James
Thank you for your query
Your keyboard settings seems to have gone a bit funny
Please try the following
1) Click Start>Control Panel>Regional and Language Options
2) Under the tab Regional Options ensure that the standards and Location are correct
3) Click on the Languages tab and then click on details and ensure the language is correct
4) Click Apply and then OK
This will resolve the issue for you
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 16, 2010 | Acer TravelMate 4672WLMi Notebook
Acer Travelmate 2500: Where's the wireless card fitted?
go to http://tim.idau/laptops download your service manual it will show where wireless card & bluetooth card are installed, good luck .
Jan 04, 2010 | Acer TravelMate 2500 Notebook
Key board problem
It would seem that the keyboard may be defective. It is a fairly standard keyboard layout, so SHIFT-2 should produce the @ sign. It looks to be a fairly cheap fix:
http://cgi.ebay.com/New-Keyboard-for-Acer-Aspire-4520-5315-5520-5720-5920-_W0QQitemZ390088823197QQcmdZViewItemQQimsxZ20090901?IMSfp=TL090901179007r413
Sep 18, 2009 | Acer Aspire 5720-6661 Notebook PC
The mouse pad on my new acer travelmate 4730 doesnt work
Hold down the function key (Fn) then press the F7 key. This is keyboard shortcut to toggle on and off the touchpad.
Sep 04, 2009 | MSI M510C Notebook
Upgraded Acer 2500 Travelmate with a Wireless card
you can find the driver from here. download and install to use Wi fi
http://support.acer-euro.com/drivers/notebook/tm_2000.html
May 30, 2009 | Acer TravelMate 2500 Notebook
I spilt coffee on my laptop. The keyboard is not working
usually laptop keyboard and touch pad have a protecting cover for situations like this, but would depends on how much, how far and how long the liquid stayed on the keyboard and pads surface.
one thing to check though.
remove again the keyboard of the book and check the keyboard cable going to the board if its tightly fix, same with all other connectors.
if still the same problem...then the keyboard is fried.
Feb 09, 2009 | Acer TravelMate 240 Notebook
Acer TravelMate 4020 Blutooth
does not have ! Look at the "communication" tab
Acer TravelMate 4020 Notebook Specification:
Operating System Linux BE (Basic Edition) Platform Intel® Pentium® M processor 725 (2MB L2 Cache, 1.6GHz, 400MHz FSB)
- Intel® 915GM Express Chipset
- Intel® PRO/Wireless 2200BG Network Connection 802.11b/g Memory 256MB DDR2 SDRAM, upgradeable to 2GB Display 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Graphics Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0 and dual independent display Audio Audio system with built-in speakers
MS Sound compatible
Built-in microphone Storage 60GB ATA/100 HDD Optical Media Drive DVD/CD-RW Combo Drive Communication Modem: 56K ITU V.92 modem
LAN: 10/100 Mbps Fast Ethernet
Wireless LAN: integrated Intel® PRO/Wireless 2200BG network connection Size & Weight 364 (W) x 279 (D) x 33.9/38.9 (H) mm (14.3 x 11 x 1.3/1.5 inches)
2.95 kg (6.48 lbs.) Power ACPI 1.0b power management standard
32.6W Li-ion battery pack (4-cell), battery life: 2.5 hours Special Keys & Controls 88-/89-key Acer FineTouch™ keyboard with 5-degree curve, inverted "T" cursor layout, international language support, 2.5 mm (minimum) key travel
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key, one user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® I/O Ports Three USB 2.0 ports
PC Card slot (one Type II)
External display (VGA) port
Headphones/speaker/line-out port
Microphone/line-in jack
Ethernet (RJ-45) port
Modem (RJ-11) port
DC-in jack for AC adapter Software Optional Items Li-ion battery pack
65 W AC adapter
256/512 MB or 1 GB DDR2 533 soDIMM memory modules
External USB floppy disk drive Warranty 1 (one) year International Traveller's warranty (ITW) Price
Jan 21, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 2500 Notebook Logo
177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
