Question about Car Audio & Video
Alpine Sound Field Processor
I have a Alpine AI-NET ERA G320 DPS. If I buy a alpine radio that is not AI-NET, is there a way to switch the processor from AI-NET mode tp manual ?
  • 578 Answers
Check the setting menu and u will see how to
Posted on Jul 07, 2009
What are the switches for on the back of Alpine c da 9984
Those are for Ai-Net accessories (CD changer, amps, etc). If you're not using anything with Ai-Net, then I suggest you leave them as they are.
Feb 07, 2016 | Alpine Car Audio & Video
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Can an equalizer cause hissing
The more ground the better,or check the RCA cables.or to see if the power wire is running any cables that power the inter.
Oct 26, 2009 | Alpine Type-R SPR-17LP Coaxial Car Speaker
On my Alpine CDA 7892 i have the aux cables right for my iPod but i don't know how to swith it to the "aux" , just CD or Radio, How do you switch it to the "aux" imput in the back
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Mar 28, 2009 | Alpine CDA-7892 CD Player
Volume will not go passed 4
The amp requires a compatible Ai-net Alpine head unit to operate it. I bought one too and didnt know this and im still trying to put all of the peices together to create a working stereo system without buying everything all over again.
Nov 25, 2008 | Alpine MRA-F350 Car Audio Amplifier
Alpine wont pick sirius up
make sure you are set on the correct frequency. both the device and the radio.
Jul 22, 2008 | Alpine CDA-9883 CD Player
Aux input problem
Here's the link for the manual: http://vault.alpine-usa.com/products/documents/OM%20CRA-1667RF.pdf
Aug 19, 2007 | Alpine XMA-T200RF FM / AM Receiver
CDA - 9833 AI-Net issue
If the radio was still plugged in when you cut it (such a BAAAADDD idea....) it likely shorted the data pins to the power pins which fried the AI net processor. There is no fix for that. It's toast.
Aug 20, 2006 | Alpine CDA-9833 CD Player
Car Audio & Video Logo
659 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
