Question about Actiontec (GT701) Modem
Actiontec Modem Won't Work!
So our dsl internet, through Qwest, was extremely slow. So my husband and his friend throught they could solve the problem. They didn't. I fixed the internet problem, but now our modem doesn't work! We used our friends modem, the internet works fine now. What they did was push the reset button on the back of the modem. Now when you plug it in, the power light glows red and the DSL and the Ethernet light blink green. No other lights are on. Help!
  • tjdurban Jan 27, 2009
    same problem on actiontec modem. Had pressed reset button. Mesed things up. Now power is red, internet and USB blinking gree, ethernet solid green and DSL off.
Pull out the power plug on the back of the modem, then reinsert it. Should reset the modem
Posted on Jul 23, 2011
Take a wire and carefully touch it to the two attachment points of the copper ring on the left side while it is plugged in. I first froze my system for 15 min then thawed out and touched the wire as instructed and all works fine.
To open the box remove the clear soft contacts on the bottom, should be four. Using a small philips remove them and pull the box in two. Then fix according.
Hope this helps
Posted on Mar 07, 2009
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
How do I reset the password and User ID on an Q1000 Actiontec Modem?
Things You'll Need
• Q1000 Qwest Wireless N VDSL Modem Router
• Computer connected to the Modem
Step1 On any computer that is
connected to the Internet, type http://192.168.0.1 in the web
browser window and then press Enter.
Step2 Click Utilities.
Step3 elect "Restore Defaults" from the menu on the left.
Step4 Click the last restore button that follows
"Restore Modem to Factory Default State
The manufacturers web site with this advice is here.
http://www.actiontec.com/products/datasheets/Q1000QwFactoryDefaultsHowto.pdf
Sep 24, 2014 | Actiontec Qwest Model Q1000 4-port...
I have DSL through Qwest and can connect to the internet, but the modem will drop internet connection then come back on then drop again. I will unplug the modem and restart it; it will connect then drop...
check the configuration of the modem if you can. I do not know the exact model of the modem, could you post it? then with the exact model of the modem you could google it for a Manual, Handbook, or simply good configurations. If the configurations are good, then could be the firmware that is not updated, or in the last case ask Qwest to change your modem for one that works.
A piece of advice don't open it or modify it because you could void the warranty, in case of a change.
Hope this help you!!!
Aug 20, 2010 | Actiontec (GT701) Modem
I have an Actiontec wireless modem from Qwest and I cannot find the SSID
If you haven't changed your SSID, the default SSID is provided on a sticker on the bottom of your Actiontec router. It usually starts with a JR
Nov 10, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Got Qwest DSL internet and now PS3 can't connect to internet. "Access Point Was Not Detected" What do I do? Modem is Actiontec PK5000. Wireless internet works fine.
I found out that the ps3 is case senitive for the password so it there is caps in the password use caps..the qwest guy gave me a password like fff3093fhfhjh3r and I had to use FFF3093FHFH blah blah
Oct 26, 2009 | Actiontec Computers & Internet
I have the actiontec gt704wg dsl modem that I got from Qwest. The last few months I often lose my internet connection. The only way I get it back is by turning the modem off for a few seconds and then...
It sounds like a firmware issue or problem. Have you tried updating the firmware of the router? If not, download the latest firmware from actiontec website and install it to your router. Note: After successfully updating the firmware, you need to hard reset the router. Press the reset button at the back of the router for 30 second then unplug the power for 30 seconds as well then plug it back n.
Oct 06, 2009 | Actiontec GT704WG Wireless Router...
We have actiontec verizon router/modem GT704WG. We have to reboot our computer and router multiple times a day to get the internet to work. It will be working, then all of the sudden it just stops, and we...
I have had this same problem with Qwest using a new iMac and MacBook on the Actiontec modem. Qwest did two things: first we reset the modem which was fairly simple and took only about 5 minutes. However, this fix lasts only a few weeks and it comes back. I have just ordered a new modem since there seems to be a problem with the Actiontec device with the newer high speed internet.
I'd try the reset before doing anything else. Good luck.
Jun 25, 2009 | Actiontec GT704WG Wireless Router...
I have a Qwest Actiontec modem that has worked fine until today. Now the DSL light is blinking and the Internet light does not come on. I have rebooted, but no fix. thanks!
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
May 07, 2009 | Actiontec (GT701) Modem
Modem speed slow, reboot modem speeds it up
THE REMOTE COMPUTER DID NOT RESPOND
Oct 22, 2008 | Computers & Internet
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Apr 06, 2008 | Computers & Internet
Actiontec (GT701) Modem Logo
1,195 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
