Question about Iomega (33600) 160 GB USB 2.0 Hard Drive
After months of use... it now asks for formatting !
I bought this external HD months ago with no problem using it/transfering files.
But now, everytime I plug it in the USB 2.0 port, I can see my drive still but i get a message when I want to open it: Need to format the disk.
Of course I said no since I have 140G+ data... How can I solve this? I thought it was pre-formatted already... I couldn't find any answer to my problem in other posts... thx in advance !
I had this very same problem...
I found good advise on another message board and it has worked!! I downloaded a program called TestDisk from www.cgsecurity.org. It's a free program that runs in a DOS form so it's a bit confusing. But it can read your files off a secondary boot. Follow the steps below and you should be ok. Hope it works for you too!
1. Start Testdisk.
2. Select [Create] to create new log.
3. Select the drive you are trying to recover.
4. Select [Proceed].
5. Select platform. I used [Intel] since I am running this on a Windows machine.
6. To restore your files, select [Advanced].
7. Select [Boot].
8. Select [List]. This will list all the files and folders on your drive.
9. Highlight each file and folder one at a time and type "c". Make sure it is a lower case "c" since it is case sensitive. This will copy the files to your hard drive.
Posted on Sep 03, 2009
  • 446 Answers
Under any condition do not format the external HDD,
try using a different USB plug.
if you have been removing this unit unnecessarily without plugging out correctly using the "safely remove hardware" there is a possibility that the USB firmare is corrupted
Posted on Aug 27, 2008
I am trying to transfer all my photos from my old freecom external HD to a new external HD, but the Freecom keeps switching itself off mid transfer, every few minutes. I'm worried I'm going to
sounds like a faulty drive, afraid without sending it off only way you will be able to get info off is by transfering it bit by bit,
best u use cut files at least u dont have to keep copying same files over and over that way
Jun 16, 2012 | Freecom Computers & Internet
I'v just bought Buffalo's external hard drive about three months ago, the problem came out about two months ago when i tried to transfer some files, and the transfer rate suddenly decreasing significantly...
Is it "slow" only on your computer, or also on some other computer?
If it _consistently_ is slow, then it probably has at least a one-year warranty. So, return it to where you bought it, and get it repaired/replaced.
Nov 01, 2010 | Buffalo Technology (USA), INC. - 500GB...
Windows easy transfer taken over external hard drive
back up your drive s data and use quick format ..it will not ask any further.
datarecoveryfactory
Aug 21, 2009 | Western Digital My Book Essential Edition...
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Nov 17, 2008 | Computers & Internet
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Help retrieving files from simpletech 320gb hard drive!
I have to admit I haven't used a Mac since high-school, but I can tell you that my first thought on this problem was "file system".
Most external HD's are formatted to be used on a Windows PC, and many are even formatted as NTFS. If this is the case, last I heard anyways, Mac OS doesn't support NTFS.
My suggestion is to use either machine to format the external HD (**you will lose all data on it**) as a neutral file system. By that I mean one which will work on both operating systems.
I could be wrong about this, and Mac OS may support NTFS, but if that's the case somone will be kind enough to correct me.
Mar 15, 2008 | Computers & Internet
Iomega (33600) 160 GB USB 2.0 Hard Drive Logo
352 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
