Question about Intel Motherboard
MOTHERBOARD REPAIR HI CAN ANY ONE TELL ME HOW TO REPAIR MOTHERBOARD OR ANY BOOKS WHICH HELP ME TO REPAIR MOTHER BOARD.I AM HAVING THE KNOWLEDGE OF ELECTRONICS AND I AM GOOD WITH SOLDERING.
  • 3 more comments
  • subu6 Aug 28, 2008
    no display no beep sound
  • Anonymous Sep 02, 2008
    have opened the casing
    have removed the motherboard safely
    what should i do next?
  • paul luyimbazi Sep 02, 2008
    yes
    tried troubleshooting first i realized later on it was the problem
    have removed motherboard safely
  • pccare Sep 14, 2008
    hi friend,
    Can you please suggest any book by which i can learn motherboard repair.please help me
    hi friend can u suggest any book by which i can learn motherboard repair...please help me
  • 28 Answers
First off, is the motherboard actually the problem? If your motherboard has failed, the screen may come on and you may have some sort of raster (brightness) but thats as far as you get. Power supply failure is (in my experience) more common than mother board failures (usually) and may exhibit the same symtoms. Also a bad battery on the motherboard will cause funky things to happen on boot. (clock not right/failure to recgonize hard drives, etc). If you are certain a motherboard is a fault you should replace it ( unless you are VERY fluent in soldering/desoldering surface mounted components and component level repair and have a solid understaning of digital and D.C. circuits) More often than not, replacing the entier motherboard is cheaper and less of a hassle.
Posted on Sep 13, 2008
How to repair a mother board with overvoltage? I would like to repair it.
Up to my knowledge, when the computer's motherboard burns out, it can't be repaired. If you feel you have the technical knowledge to do it, welcome. I don't believe anyone in Fixya can guide you how to do it.
Jun 09, 2015 | Apple iMac Computers & Internet
How to repair motherboard from starting steps to end
Are you serious? You DON'T repair the mother board, you replace the entire thing. You need skills, very good skills to do this, read lots of books on electronics, or go to a school with technical courses. Then you need tools and test equipments, such as Oscilloscopes, Digital Training modules, Solder station. Multi tester, Hot Air gun, Anti static equipments. Wave generators, computer equipments and testing tools, and the most important Analytical Thinking. Or simply Replace the entire board.
Aug 09, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My Laptop DV6000EU in Aug 2007. Warrenty on Mother board
it should be under waranty seeing that the motherboard is malfunctioning again. normally the hardware will go out before the motherboard and seeing that its the same problem again mark the motherboard in a nice little place with a marker to insure they are not doing a repair and giving you back the same faulty board.
Nov 12, 2009 | HP Pavilion dv6000z Notebook
Repair Mother board in Mumbai
Actually it will be better to have a new mothereboard rather than having it repaired because even if you have the MOBO repair you will always have some problem with becuase everything is interconnected on the motherboard if you start having some problem with any partys sooner or later you will also have some problem with other parts of it so just to have a better performing system I suggest you to get a new one....
Hope that helps............
Sep 30, 2008 | MSI K8MM-V Motherboard
I don't have mother board cd
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
40
Jul 20, 2008 | Intel Motherboard
Problem with my motherboard
i can not find the seristor for the motherboard because the mother board did not open. I put the power cord and i turned on but the fan over the CPU does not working and there is no reponse from the mother board. I change the power supply . it gives the same. so i asked someone he told me there is an seristor in the mother board maybe damadge but i cann't find it can you help me >>>> my mother board is Gigabyte (Model 8S661FXMP-RZ ) Pls Help !!!!!!!!!!
Apr 29, 2008 | Intel Motherboard
NO BIOS
to get bios set up you must press DELETE key or F2 to enter set up...
you do this at the time of the booting ....
if your bios is corrupted then you can restore the bios by changing the bios jumper to restoration mode to do this refer to your motherboard manual...
Feb 22, 2008 | Intel Motherboard
Hi dear
tell me your problem @ shree_nampur@rediffmail.com
Feb 09, 2008 | ASUS P5PE-VM Motherboard
Intel Motherboard Logo
1,090 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
