Question about Epson Compatible T033120 Black Inkjet Cartridge for Stylus Photo 950 / 960 Inkjet Printer
Epson Stylus CX3650
Whenever I print a photo the black ink smudges at the bottom of the photo, but i can print documents and everthing else and do not have a problem can you please help me with this .I am 76 years old and love to work om mt computer thank you.
  • 446 Answers
Either the problem is the media or the material you are using is not properly fused or fully adhered onto the surface
try using a different paper or media, and try printing your photo in between with a different kind of images.
or there cold be a prob in the fusing unit of your printer
Posted on Aug 27, 2008
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
There are black ink smudges on the bottom corners and edges of my color prints on velvet fine art paper. How can I stop that from happening. I already cleaned the heads twice. The prints are great...
The R2400 has an option to load paper on-top (Epson calls it the Automatic Document Feeder) and at the back. Based on the printer's User Guide the Velvet Fineart Paper should be loaded at the back. (Epson called is the Manual Single Sheet Feed).
Look at the User's Guide availabe on their website.
Jan 19, 2010 | Epson Stylus Photo R1800 InkJet Printer
Re: epson 1290s - black smudges
make sure ur catridge is not leaking just remove the catridge and clean with tissue paper and try.
Sep 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
When printing, black lines appear on the sides or black smudges. We had the cheap ink for a while and it started doing this then we switched back to the epson ink but it is still happening and it only...
That is the problem with epson, the separated head and ink. Possible the problem is in head. Try make printet pieces :) and remove printing head, and use Isopropyl alcohol to wash it, if possible to let it to make a bath for 1 hr. and dry it. hopping the electronics and cables are ok.
Jul 01, 2009 | Epson Stylus C66 Photo InkJet Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Urgent: red light error on Epson Stylus CX3650
It appears that this is an overseas model (at least for those here in the US that is) as far as I can tell. This will use the same drivers as the CX3600 model though. Depending on how long you have had this and how often you use it, you may have a waste ink reset situation. While I have not had any personal experience with this model, there are several references on the internet on how to do a reset. There is even an "SSC Service Utility" you can search for that lists this printer as being supported. It cannot reset the ink counters but it may reset the waste.
Good luck, I hope this is of some help.
Oct 18, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus CX3650
the head of ink is damage.
- are you using refill ink before ?
coz it may damage d nozzle of printer
Aug 26, 2008 | Epson Office Equipment & Supplies
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
How to?
that's in the settings panel, under printer settings..set it for greyscale
Aug 03, 2008 | Epson Stylus RX580 InkJet Photo Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
