Question about Kyocera 7135 Handheld
HotSync hangs at end when backing up files and using VersaMail 2.5
This only happens when VersaMail 2.5 is set to synchronize through the conduit. If set to do nothing everything is fine. This started happening after the most recent security update for Outlook 2003. Chappura's Pocket Mirror is updated to the most recent version. This is on my Kyocera 7135
2 Suggested Answers
2 Bunny
  • 18 Answers
SOURCE: my 7135 kyocera is locked to verizon service i need the code to unlock so that i can use the phone with my current service provider,the phone is a gift my sister the previous owner
All you need to do is install palm desktop. This should have been included with the CD in your package. If for some funny reason it is not, go to here.
But don't forget to plug in the USB/Serial cable (whichever you prefer to use), then, select USB or serial after installing palm desktop (just right click the HotSync manager and if your choice isn't selected, go ahead and do so).
Hope this helps!
- 2 Bunny
Posted on May 26, 2008
How can I delete VersaMail from my Palm T/X? I never use it. Thanks
The easier thing, would be to simply disable the conduit. Set the conduit to "Do nothing" via the HotSync Manager's "Custom" menu item and check the "Default" checkbox. Then the sync will just blow by the VersaMail conduit as if it wasn't there.
Or you can purchase Conduit Buddy:
http://www.livepim.com/condbudy/index.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 12, 2009 | Palm TX Handheld
Unable to sync with outlook 2003
Try to change conduits to hotsync with PDS, if it will work then the problem is with the MSOutlook.
Sep 12, 2005 | Palm Treo 650 Handheld
Inbox messages syncing mysteriously
Turn off the conduit. It sounds like you dont want the Mail to synchronize at all. You can set the Mail or VersaMail conduit to Do Nothing permanently if you would rather not have mail synchronizing. Go to HotSync icon in your system tray and click on it. Select Custom... Make sure your username is selected and then choose the mail conduit. Set it to Do Nothing and ensure you check the box 'Set as Default'
Sep 12, 2005 | Palm m125 Handheld
Treo 650 is not syncing with outlook calendar, but syncing with everything else.
You may have tried Exchange ActiveSync in VersaMail When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo. So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Calendar Not Syncing
OK. Hope this helps you because it fixed my problem. Go into palm desktop. Go to hot sync, click on custom Go to Calendar (Outlook) and double click on that. At this point click on settings. Under conflict resolution choose "outlook wins". Then go out and check syncronize files and set as default. Click done and this should resolve the issue. Reply if this is confusing.
Treo 650 won't sync with Outlook calender on my Windows XP Pro desktop?
I was tring all the possible ways to resolve the issue. At last got a solution for my problem. Hope this will work for you all. Download the "OutlookConduitUpdater.zip" and install. This will resolve the calender "do nothing" while sync.
No synchronization when Outlook express is default mail program
Email synch is based on current MAPI preferences. The problem you have is that the VersaMail conduit assumes your mail client must be the MAPI default email client. You could adopt another profile in Outlook instead of OExpress which picks up the account you use in OE. This is the first instance of this problem I have ever heard of so I doubt if PalmOne would make a software change on this.
Sep 11, 2005 | Palm Tungsten E Handheld
Is possible to sync only a specific folder of Outlook?
Yes - you can specify which folders. By default the VersaMail conduit synchronizes the Inbox folder from your Outlook/Exchange account. If you do just as you mentioned creating a MyPalm folder, you will be able to have only that folder synchronize. Open up the Custom menu item from the HotSync icon. From there select the VersaMail conduit and double click it. Select the account from the dialog that appears - if you have multiple VersaMail accounts, the one to choose is your Outlook profile name. Then click on the Advanced button. Choose the rightmost tab which is called Folders. Here you can individually select the folders which do and which do not synch. Turn the Inbox folder to No and turn the MyPalm folder the Yes. That is it.
MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Sep 11, 2005 | Palm m130 Handheld
Treo 650 from Cingular is not hotsyncing with Outlook Calendar?
Have you setup an EAS account in VersaMail? The VersaMail application on your Treo 650 supports Exchange ActiveSync, which allows synchronization of Email and Calendar wirelessly with Exchange Server 2003. If an EAS account exists on the handheld the Calendar conduit will disable itself to avoid duplicates. Go to VersaMail on your Treo650 Select Menu: Accounts: Account Setup Check to see if any EAS accounts exist on the device by selecting and account, then Edit... One the first screen check Mail Service. Do any of them say "Exchange Activ..." If yes you'll need to delete that account to sync calendar entries.
Sep 07, 2005 | Palm Treo 650 Handheld
Kyocera 7135 Handheld Logo
27 people viewed this question
Top Kyocera Computers & Internet Experts
samrat101
Level 1 Expert
Marvin
Marvin
NOEL
NOEL
Are you a Kyocera Computer and Internet Expert? Answer questions, earn points and help others
