Question about Panasonic Panafax UF-890 Plain Paper Laser Fax
Confirmation Page I need a confirmation page after every fax that i send. What should I do? I would like a confirmation sheet after every fax in order to assure that the recipient has successfully obtained the correct information. I have read thru the manual and have not been able to locate the proper programming instructions.
    Genius:
  • 2,120 Answers
Function 74 set 12 set 2 set stop.
Posted on Aug 30, 2008
Printing a confirmation sheet after every page is faxed
Navigate to the Settings on the Printer itself, Under Settings there would be a column which would say Fax settings, Under that you would see an option to Turn it Off!!!!!
Good Luck!!!!!
Apr 02, 2013 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How do i get my fax machine to print out confirmation with 1st page faxed
go into you fax options just look for conformation send or confirmation on fax error you sould be able to find those options in the general fax setup.
Oct 12, 2009 | Office Equipment & Supplies
FAX MACHINE NOT PRINTING CONFIRMATION PAGE
How do you get a confirmtion page after faxing on a Canon 3235i imagerunneer
Sep 08, 2009 | OKIFAX 5650 Plain Paper LED Fax
FIRST PAGE PRINTING AFTER SENDING FAX
Scroll through the menus for REPORT PRINT to set confirmation.
Jan 27, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Dec 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic Panafax UF-890 Plain Paper Laser Fax Logo
225 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
