Question about HP iPAQ RZ1715 Pocket PC
Rz1715 continually reseting
My ipaq rz1715 would not start last night, so I tried to reset. THe reset screen came on for a few seconds, then went blank. Then the reset screen came back on, then went blank, this continued until the battery died. I tried several times to turn it off or reset again--- no effect. Once the battery ran down, I plugged it in, it would not start, when I reset it, it started doing the same thing-- begin reset, then turn off, over and over until unplugged. What now? THANKS
    Master:
  • 450 Answers
Charge it overnight then do a hard reset... You will lose any data or files that you have added, but if a hard reset doesn't fix it, you should return it to HP...
Posted on Sep 07, 2005
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so
    3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
Hi I treid to do a ROM update on my HP iPAQ 4150. The update stopped and the screen now shows 1.05H and 1.02 and only the HP logo. Does not go anyfurther. Furthermore the iPAQ is not recognized by...
I ran into the same issue with a H4150. Pull the main battery and let it sit without the battery for a while; a few seconds is not long enough. I let it sit for about two minutes and that was long enough on each of the four times I needed to recover from a failed ROM upgrade last night. This reset the H4150 and it then initialized like it was just out of the box; all data and settings were reset to original. Some troubleshooting procedures indicate you should not use a USB hub for this process. That did not work for me-the ROM upgrade still breaks the connection just after getting started. But at least pulling the battery got the iPAQ back to a useable condition. My next test will be to try it from an old PC with Windows 98 and USB 1.1 or 1.0. Maybe the brief disconnection is normal and a fast PC with a modern OS may not be as forgiving to brief upsets. Just as the ROM update really begins (after all the handshaking), the iPAQ briefly drops the connection and that's when the update fails, it just takes a little longer for the software to say 'hey-I've lost communication with the iPAQ...'
Oct 03, 2010 | HP iPAQ H3835 Pocket PC
How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Mar 17, 2009 | HP Computers & Internet
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
Ipaq 2490 hangs on booting
Try this:
4. Make clean reset (hold callendar + itask, then press and hold reset), after about two seconds you will hear knack. Now unhold these buttons. The screen will be black.
5. After that make hard reset (hold callendar + messaging + power and then press and hold reset) after about two seconds unhold reset button first and after about one seconds remaining buttons. You will see on screen PS FORMAT.
6. Now is you iPAQ ready.
Nov 24, 2007 | Computers & Internet
Hard Reset
On the front pannel you have the 4 buttons and the central navigation key. Press simultaneous the first and the last of this buttons (1 and 4) and then with your stylus (while keeping these buttons pushed) press the soft reset button (bottom of the device, a small hole). Keep these pressed alltogether for 4-5 sec then release them and do a soft reset. Your PDA should now be in factory settings. If not, try again. It will work.
Feb 19, 2007 | HP iPAQ RZ1715 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
HP iPAQ RZ1715 Pocket PC Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
