Question about Samsung SyncMaster 712N 17" Flat Panel LCD Monitor
Monitor display suddenly bad
Never had problems with monotor, Suddenly last night I have horizontal lines of various widths and shades of gray over the whole screen. The quality of the display is also bad, colors are not true, overly bright and lettering is fuzzy.
    Problem Solver:
  • 7 Answers
Monitor has just died.
Posted on Aug 28, 2008
Samsung UN40D6000SFXZA TV has blue screen with vertical lines of various shades of blue.
You may try a new T-CON, but most of the problem could be a display panel.
Nov 01, 2017 | Samsung Televison & Video
My computer's all windows screen has suddenly shrunk today with a black border in right and left side. Now how can I get ride of this problem and make my windows screen normal again?
It's probably the monitor either was adjusted or is having a problem.
Use the buttons on the monitor to adjust the horizontal width on the screen...This should stretch your windows display across the screen if you adjust properly. Most monitors also have an auto adjust option...you can try that too.
I can't tell you exactly what the menu options are, because I don't know the buttons on your monitor. but if you find the menu, you should be able to make the adjustment.
Good Luck
May 26, 2011 | Computers & Internet
Monotor not working
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Here is the disassembly guide:
http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
Hope this helps.
Oct 24, 2009 | Toshiba Satellite M35X-S161 Notebook
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
LCD Display - Gray Shades/Lines
1ST OF ALL U SHOULD CHECK UR CPU WITH ANY OTHER MONIOR IF IT WORKS OK THEN BUY 256MB XFX 3GP CARD
Dec 14, 2007 | Gateway GeForce2 NV15, (64 MB) Graphic...
Samsung SyncMaster 710N 17" LCD Monitor - Grey screen
Does this unit have an external power supply (wall wart)? If so, substitute a known good one of similar specs. If the original is 12 Volts/1.2 Amps, find a 12-15 Volt/1.2 or greater Amp. DO NOT go over the voltage more than about 15-20%. DO NOT go under the current rating less than 90% for just long enough to see if it works. Be sure the connector fits PERFECTLY!!! Some will appear to fit but will be loose. Do not under any conditions replace a DC supply with an AC one or vice-versa.
Sep 12, 2007 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung SyncMaster 712N 17" Flat Panel LCD Monitor Logo
202 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
