Question about Palm Handspring Visor Platinum Handheld
How do I update my palm with outlook???
Thanks
    Master:
  • 903 Answers
1. make sure Outlook is running on the PC 2. make sure hotsync is running - right click on the hotsync icon in the system tray - click custom - set all the things you "want" to sync and setup the way you want them (i.e. handheld over rides PC, they both sync, etc) 3. have VersaMail configured and setup as well...that's where your Outlook mail will come from 4. Push the hotsync button on your cable/cradle This should get you started. If I missed a step, it should be obvious in the Hotsync log, so check the log after doing a Hotsync.
Posted on Sep 07, 2005
Having loaded Ooutlook 2007 and the latest updates for my Plam Tx I am no longer able to sync my calendar.
If you use Microsoft Office Outlook 2007 on Windows XP or Windows Vista, you'll need this update to perform Sync operations with Outlook's Calendar, Contacts, Tasks and Notes, as well as optional non-wireless Email sync.
Here's the link for the update first detach your palm from pc then just click, download update and restart your pc
http://palmone.r3h.net/downloads.palm.com/palmoutlook2007conduits.zip
Apr 02, 2010 | Palm TX Handheld
Tx will no longer sync with outlook 2003 or outlook 2007 calendars. Software reinstalled, tx reset, latest updates for syncing with outlook 03 and outlook 07 loaded, still won't sync to outlook calendar...
I would recommend contact the palm free chat. Here is a link for that. I have a TX and have used the chat feature myself and always with good results. Scroll to the bottom of the page and then you will see Palm chat. From there click on chat now and follow the directions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm TX Handheld
Double entries in Palm and Outlook
The closest I have come has been from a firmware update for the Palm phone. After the update, the phone saw my original contact list and created a second contact list from what was present in the Palm calendar.
If you have changed firmware and this issue started happening, you'll need to delete the duplicates in Outlook or it will continue to try and update/save them. Also, this is most likely why your sync sessions are taking more time...the phone is trying to read the different entries already present in outlook, and it is taking time to default when it cannot open the entries. Multiply that time by 4 or 5 times per entry and you have a very long sync session.
Hope this works for you!
Apr 02, 2008 | Palm Treo 650 Handheld
Switching to the MS Outlook Conduits using the Palm Installation CD
Search Installation Disk, I had this same issue. The Outlook conduit is on the installation guide, you have to search for it. 1. Insert the installation disk. 2. Open My Computer 3. Right click the drive that contains the disk. 4. Click Search. 5. Enter the conduit name for your device (ex: Pocket Mirror) 6. The search results should contain the executible file that you need to run to sync with Outlook. Hope this helps.
Sep 13, 2005 | Palm Tungsten C Handheld
Hotsync creates three copies of everything in Outlook
try to update the chapura to 3.1.7.1, it is available free of charge in chapura.com. outlook 2003 came with some new features, that is why it is always wise to think to update your tools whenever there is a problem. just make sure that that u close outlook while installing the updates..... best of luck
Sep 12, 2005 | Palm IIIxe Handheld
Tungsten E - HotSync with Outlook 2003
Don't skip the initial HotSync for secondary computer! Alright, I figured this one out on my own and figured I'd post what I'd learned so that others don't have to endure the teeth mashing, hair pulling, snarling frustration. (self induced as it may be) My experiences have taught me to not always trust a cookie cutter installation wizard...especially for custom app installations (ie: primary = home, secondary=work, total sync, no priority). So, I did not perform the initial sync during installation of the palm software fearing that the new installation would NOT recognize that the work computer was a secondary machine and resultantly wipe out the old palm data from the primary machine. Turns out, as I saw in many other unrelated posts, that it's difficult (if not impossible) to specify conduit direction to outlook 2003 outside of the initial sync (this prompted me to specifically look for conduit direction during install). So, this wizard is one I should have trusted...by mistake...because of weak program design. By the way...once I specified sync with outlook during the initial sync, EVERYTHING works fine despite not having installed the two "imperative" conduit updates (they were uninstalled after several previous failed attempts at this). Hope this helps
Sep 12, 2005 | Palm Tungsten E Handheld
Want Microsoft Outlook to dominate - two computers
Update dominance in Palm Desktop app. Figured it out! Go to the Palm Desktop application. Click on HotSynch, and then Custom. On each of the four Outlook conduits, click "Change", and specify that desktop dominates, if desired.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Hot sync does not work
"PLEASE SET SYNCHRONIZATION OPTION ENABLE SYNC WHEN OUTLOOK IN UI IN ORDER TO SYNC IN OFFLINE MODE" Just go to your Hotsync Manager icon Click Custom Click each Outlook conduit ex. Calendar Outlook Click Change Click Settings Check the Box that says Enable Synchronization when Outlook is Offline Then do same process for Contacts, Tasks and Memos. Wherever your updated data is..make sure you set Action of conduit to example: Desktop Overwrites HH (if your OUTLOOK has the most updated data.) Hope that resolves your problem.
Sep 11, 2005 | Palm Zire 72 Handheld
Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
Sep 11, 2005 | Palm Tungsten E Handheld
HEEEELP!!!!!!!!!!!!! outlook 2003 and Palm do NOT sync!
you need to have pocketmirro installed in your desktop in order to sycn with your outlook..
Sep 11, 2005 | Palm Tungsten T2 Handheld
Palm Handspring Visor Platinum Handheld Logo
106 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
