Question about Tamron 18-250mm F/3.5-6.3 AF Di-II LD Aspherical (IF) Macro Lens for Konica Minolta and Sony Alpha D...
How to get the lens apart to clear bits on the front element
Hi have recently purchased this lens from ebay second hand, and there appears to be sand or something inside.So i was wondering how easy it was to take it apart to blow this stuff out?.It is a pentax fit lens.
  • kakima May 11, 2010
    Taking a lens apart is not that hard, you shouldn't need much more than a set of small screwdrivers. Putting one back together is a totally different matter...
    Do you have a lens collimator? Without one, you're not going to be able to make sure the lens elements are properly aligned.
The front element is easy to remove.
There's a plastic cover on the front of the lens which has a very small hole in it.
Get something like a very small screwdriver in that hole and prize the cover off.
Remove the 3 screws in the next plastic cover and remove it.
The next 3 screws you see hold the front lens element on.
This whole part rotates to adjust the infinity focus and is kept in position by those 3 screws.
Make sure you mark the position by maybe making a small scratch in the plastic next to one of the screws.
Or maybe scratch around one of the screws.
With those 3 screws removed the front element with the lens just falls out.
Posted on Feb 06, 2013
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Tamron Master
  • 102,366 Answers
Unless you just happen to have a lens collimator handy to ensure that you've got the elements in parallel, I wouldn't even consider taking the lens apart. And, I suspect, if you have a lens collimator you wouldn't have asked this question.
Leave this job to a professional with the tools to put the lens back together again.
Posted on Feb 05, 2010
Please Help. I have a Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX. I occasionally remove the front lens element assembly to clean the inner lens element as it gets dusty. The front lens element assembly...
Hi,IF I were you I will search the eBay for a same lens as " parts only " which means lens does not work but you can use the some parts of it ..There are a lot on ebay..one example is below URL..pls visit both..
Brand name services always do this..Since you were doing unauthorized repair ,they do not like it..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Item condition:For parts or not working
http://cgi.ebay.com/Nikon-Nikkor-18-200mm-ED-AF-S-3-5-5-6-READ-/200635517251?pt=Camera_Lenses&hash=item2eb6cf0943
parts;
http://photography.shop.ebay.com/Lenses-/3323/i.html?_kw=Nikon&_kw=parts&_dmpt=Camera_Lenses&_stpos=&gbr=1
Jul 29, 2011 | Nikon Zoom-Nikkor 18-200mm f/3.5-5.6G...
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Hi, Recently I bring my kid to the beach and use Sony V3 to capture some photo, but my kid throw some sand toward me and the camera. Now i found that some sand enter the zoom lens and i can heard when it...
You're going to have to take the camera into a camera shop to have the lens cleaned. There are special tools and other items that you need to have to take the lens apart and put it back together. I would phone around to different camera stores in your area to see what they would charge you to do the cleaning as it will probably vary quite a bit from shop to shop.
Jun 29, 2011 | Sony Cyber-Shot DSC-V3 Digital Camera
Nikon 28-105mm lens works okay but the focus feels "gritty" as if there is a little bit of sand in the gears. My concern is that it is on the verge of breaking and becoming unusable. Is the focus...
The "grit" is most likely between the two lens barrels and the more you use it the more damage it may cause. Cleaning and repacking/sealing a lens like this should not be attempted by people with out the proper equipment and knowledge. Basically if you take one of these modern auto focus lenses apart without the proper tools to realign and set the internal lens elements you have pretty well destroyed the lens. The Nikon 28-105 is a great lens and worth in my opinion the small amount of money to have a professional person service it.
Jan 14, 2011 | Nikon 28-105mm F3.5-4.5 D-AF Lens
How would i get a dent out of the front pipe of a dep exhaust rite on the bit where dep is? model fits a yz 125 2001. thank you for help
hi ryan,well i would tig weld a steel rod dead centre of dent and try pull the dent back out,then cut the rod and smooth weld with a angle grinder with a sand disc on,you cant get a dent out fully if its big,but you will have it looking a bit better,or if it bothers you everytime you look at it buy a second hand one from ebay.
Nov 25, 2010 | 2003 Yamaha YZ 125
My granddaughter has recently rented an apartment and the dishwasher leaves undissolved clumps & loose bits of dishwasher detergent powder once the cycle is complete. Neither of us has ever used a...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Hotpoint HDA2000G Built-in Dishwasher
Broken rear lens element on Nikkor Noct 58mm 1:1.2 lens
I recommend to call Barry Edmonds Nikon technician at Fixation UK LTD
44 20 7091 2550
All Best
Rafal
Jun 16, 2010 | Nikon Cameras
Lens error please help!!!
If the sand is in the zoom gears or auto focus gears then the camera would need to be disassembled to remove. Nice thing about this camera is that no soldering is required to take apart. A few small screwdrivers, and some tweezers would be all that is required. Canned air and a needle might also be helpful for removing the sand. If the camera just buzzes then I would say that the sand is in the auto focus gears (the stepper motor will buzz). If the auto focus lens is not fully retracted then the camera lens will not go back in (to prevent the auto focus lens from bumping against the shutter assembly)
May 11, 2009 | Canon PowerShot SD1000 Digital Camera
Problem with the lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 25, 2009 | Cameras
My polaroid i633 won't work!
YOur camera is looking for verification that the lens is extending. Once it sees the lens has extended when you power on, the sensors in the lens tell the Operating system that the lens is Ok.
If it does NOT see verification from the lens, it shuts down. Never force your lens back in. You may have to take the camera apart to reset the lens. you do this by removing the Zoom gear drive assembly and free you lens up by hand. 1 grain of sand or grit is like a Monkey Wrench in a Gear cog. Clear the obstruction with a can of compressed air, and work the lens with your hand. once you can that put it all back together and it should work.
Mar 15, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Tamron 18-250mm F/3.5-6.3 AF Di-II LD Aspherical (IF) Macro Lens for Konica Minolta and Sony Alpha D... Logo
234 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
