Question about Palm Handspring Visor Platinum Handheld
Hot Synch Manager SET UP does not show USB
I am unable to hot synch at all. I have a VISOR (2000 model). I have Windows XP Profession. I was able to hot synch yesterday but not today. I did update all software - Palm Desktop to ver 4.0.1, Pocket Mirror to ver 3.1.7, and Hot Synch Manager to ver. 4.0.1. Can someone help me!
  • 473 Answers
SOURCE: Why does pocket mirror trawl through all items when synchronising a calendar
Copied from the chepura site: These abbreviations indicate a certain type of synchronization. 1. "Forced Recovery Sync" or "–RS" indicates a Recovery Synchronization. This will occur in the following instances: * It is the very first synchronization. * There was an error during the previous synchronization. * The "Category/Folder" setting has been changed. * The Root Folder has been changed. * A record count mismatch occur has occurred. * The "Handheld Priority" has been changed. * The User Name has been deleted from Chapura Settings. 2. The "–SS" indicates a Slow Synchronization or Slow Sync. Note: A Slow Sync is necessary and does not indicate a problem with synchronization. A Slow Sync will occur in the following instances: * If you synchronize your handheld at one PC and then synchronize it at another PC, the first time you sync at the second PC it will do a Slow Sync. * The first sync after changing the HotSync action from "Do Nothing" to "Synchronize" the files. * The option to synchronize every so many days has been selected. * The first sync after a synchronization that failed. 3. The "Update Sync" will occur when the following changes have been made in "Chapura Settings": * The Location Delimiter has been changed. * The Meetings prefix, "Mtg:" has been added to meetings that have attendees in Outlook. * Private Items are filtered. * The settings for the Transfer of Alarms has been changed. 4. The "–HP" indicates that your synchronization option was set to "Handheld Overwrites PC". 5. The "-PH" indicates that your synchronization option was set to "PC Overwrites Handheld". 6. The "HH" you see during a synchronization indicates the software is reading items from the handheld. 7. The "OL" you see during a synchronization indicates the software is reading items from Outlook. These are only informational messages and do not indicate there was a problem during the synchronization.
Posted on Sep 11, 2005
  • 4102 Answers
SOURCE: Palm M515 hot sync problem
Hi you could either have a problem with the lead witch is the cheapest problem to solve the other problem is with the palm top itself if this is the case then you will need to send it off to get the firmware updated you cant do this yourself because you cant get the correct software to do this you might even need to put the device in recovery mode to install the latest firmware so it will need sending off to do this if you contact customer support number for your device then they should tell you the best way of doing this ok
Posted on Feb 11, 2008
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Just_Bobz
  • 448 Answers
SOURCE: appropriate software for tungsten e2 palmOne
If you said you have the software (desktop), your doing it backwards. Run the desktop software by going to my pc and running the disc. The software will then ask you to plug in your E2 so it can register it. It will then synch and your in business. Had E2 for a very long time. Can tell you things that guy can do that would surprize you. Have everything but unit now.
Posted on Dec 31, 2008
SOURCE: When my PC locked up
maybe a factory reset may help, please first read these posts below, first, then make a decision as to what to do.
In order to hard, factory, reset your palm, you must press the reset button on the back (with the top of the stylus, or an opened paper clip) while holding down the power button.
You then let go of the reset, while still holding the power button. When you let go of the power button, you will see the Palm splash screen.
Once you see that screen, let go of the power button. You will be prompted to press "up" on the D-navigation button to delete all data. Do so, and your Palm will be totally reset. Now it should be as from the factory... However ALL ANY personal data may be deleted, so it is advisable to have a backup before one does this. This will/should however restore everything, then hopefully you can then put back the calender files data.
Also you may also be able to mount the unit under windows, and go to where you changed those files and change them back to what they should be, this too may help. There is software on the 'net, that can assist with the mounting of these devices, to do this.
See this post below...
http://forums.palm.com/t5/Windows-HotSync/Tungsten-E2-erased-all-calendar-items-How-can-I-restore-them/td-p/316005/page/2
Below is your user guide, below that is your handbook.
www.palm.com/us/support/.../tungstene2/.../tungstene2_handbook.pdf
www.palm.com/us/support/.../tungstene/TungstenE_HB_ENG.pdf -
The TE2 manual at Palm.com, User Guides, Managing your calendar, a 37 page PDF file, page 22:
Open the Purge dialog box:
a. Open the menus.
b. Select Purge on the Record menu.
Select the events to purge:
a. Select the Delete events older than pick list and select a time frame.
b. Check the Save archive copy on PC box if you want to place a copy of the deleted events in an archive file on your computer the next time you synchronize.
c. Select OK.
Posted on Apr 26, 2011
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
I have a WD2500 installed in an external drive enclosure connected to my comp. running XP. I have the jumper on cable select. It is connected via USB. When I turn the enclosure on, the drive spins up, and...
Please check if your HDD is visible in storage management. You must be logged on as Administrator or as a member of the Administrators group view and modify most properties and perform most computer-management tasks.
To start and use Computer Management on the local computer:
  1. Click Start, and then click Control Panel. Click Performance and Maintenance, click Administrative Tools, and then double-click Computer Management.
    The Computer Management window for the local computer is displayed. "Computer Management (Local)" is displayed at the root of the console tree.
  2. In the console tree, expand System Tools, Storage
Then check if your USB HDD is visible under one of next options. This is for windows XP.
If it will be presented there try to right click on this drive and format hard drive. Also please recheck your jumper position. This picture might be very useful c33351b.gif
Oct 24, 2010 | Western Digital Caviar WD2500BB 250 GB...
Handspring visor pro on Vista
The easiest way to do this is by usb. You will need to download the 6.2 palm desktop/hotsync manager (yes, it says it will not work with your prism... I know.) Then you'll need to download pimlico's palmhotsyncsetup tool, that will allow it to work.
You can read the full instructions and get the appropriate links here:
http://forums.palm.com/t5/Windows-HotSync/Windows-7-and-Vista-hotsync-instructions-here/td-p/251755
Mar 06, 2010 | Handspring Visor Pro Handheld
I have just bought this webcam for my mac but seems unable to set up
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Dec 20, 2009 | Creative Labs Live! Cam Notebook Pro...
Out of synch sound & video Panasonic NV-GS17
Hi, did you get the issue resolved? i have te same problem an it is becoming a nignmare!
Aug 09, 2009 | Panasonic NV-GS27 Mini DV Digital...
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Drivers for Multimedia Player
Ignore the disc that comes with the player.
If using windows media player I simply ripped the tracks off the cd into mp3 to get them into the windows media library then synched the tracks to the player.
When you connect the USB cord between the computer and the player, windows media player will recognise it and show it in the left side bar.
Click on the mp3 player icon and then synch the tracks into the plyer list to import to the player (right side bar) I simply synch them all then remove the ones I dont want or drag and drop the mp3s from my media library into the player list to be synched.
Ignore totally the disc that comes with the player it is not required I think its only for 98 users to make it work it is not required with XP or Vista simply upload tracks to the player using a media player such as windows or real player.
So rip mp3s from the cd you want ....
When in mp3 mode (ignore if already mp3 on your pc) click the player icon when connected to the pc with the USB cable then select synch.
Dec 16, 2008 | Audio Players & Recorders
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Migrating software and data to new computer
Assume that your Visor is your data respository. So you should make sure that you have an up-to-date synchronization from the NT PC. Now get the XP compatible software for your Visor from the palmOne website and install it on the XP box. I assume that you will be synching via USB this time - this is the default setup when you install the software. Hopefully you still have the USB cradle that came with the Visor. You can still use serial sync with XP but you should try to take advantage of the speed of USB on the new PC. Download for XP & Visors: http://www.palmone.com/us/support/downloads/visor/win_desktop_401.html Once the software is installed, sync with the new computer and all your data should be copied from the Visor to your PC in the first synchronization. By the way, Outlook shouild be installed on the new computer before you install the Visor software; otherwise the installer will not offfer to install the PocketMirror conduits.
Sep 13, 2005 | Handspring Visor Deluxe Handheld
Palm Handspring Visor Platinum Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
