Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
53 inch Panasonic tv would not turn on..red light blinks 3 times
You suggested replacing the 1 x 2.2 ohm watt metal film resistor for this problem... just wanted to make sure i have it right. Also what kind of tool will i need to get to put on the resister?
  • Panasonic Master
  • 8,617 Answers
Just a regular solder Iron will do just unsolder the old resistor and solder in the new one
Posted on Aug 28, 2008
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
The red led flashed 3 times and stops and then repeats the steps. I replaced both convergence IC's. I still have the same problem.
Did you replace the 2.2 ohm 2watt resistors. If the led blinks 3 times its almost always going to have at least 1 of the 2.2 ohm resistors blown.
Mar 30, 2010 | Panasonic PT-53TW53 53" Rear Projection...
I need to identify the parameters (rating) of a resistor for a Panasonic PT53WX53G projector big screen tv. It got hot so I can not see the color codes on it. This resistor glows red when TV is turned...
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Resistor identification
Hi fccjben;
The color code is as follows: blk = 0; brn =1; red = 2; orange = 3; yellow = 4; Green = 5: blue = 6; violet=7; Grey = 8; white = 9
Unfortunately, if it is wirewound, they usually printed the resistor value on the body of the resistor. For sure it shouldn't be glowing. Sorry I can't be more help, but without a schematid, can't do much else
Good luck Loringh
Magnavox 55'' Projection - Sides come in and out
sounds like Convergence issue.... I have some pictures of the bowing picture TV on the link below...
I'll post you my general message which is for a similar Philips Magnavox 51 inch TV, you'll need to check the manual verify the correct IC convergence chips and resistors, the manual link is below as well... usally the IC's are STK392-120's or 150's and the resistors are 6.8 ohm 12 of then...
anyway read the general post below it will get you headed in the right direction.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture looks like it is in 3D
Yes you need to replace both convergence ICs. They are both STK392-150 you will also need to replace the 6 feed resistors. You will need ( two ) 1.8 ohm 1watt metal film resistors.
( one) 3.3 ohm 1watt, ( 0ne) 2.7 ohm 1watt, ( one) 4.7 ohm 1 watt, and ( one ) 2.2 ohm 1watt . The resistors are all 1 watt metal film resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures, plus free tech support.
http://servicemanuals.vstore.ca/
Jul 30, 2008 | Hitachi 46F500 46" Rear Projection...
Sudden shutdown - Red light blinking 3 times
Replace both convergence Ic's Stk392-110 and personally I'd use STK392-150's for greater reliability. Also check all 2.2 ohm 2w resistors for open or change in value and replace as many as needed...
Bill
Apr 18, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Resistor
sorry I got the last4 letters in the part number wrong. Its a 100K 1/10 watt metal film but the part number is ERJ6GEYJ104V the other part number was for R7058 which is 3.3 K. Small print on the parts list. Order that number its for the 100k ohm resistor that you need.
Mar 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
